Warren Nethercote wrote:
Andrew,
We built an addition on our house some years ago and while our existing furnace was big enough, the ducting runs were too long and we could never get heat in there - there was about a 4C drop from the rest of the house. A couple of years ago we added a mini-split to that part of the house and solved the heat gradient problem. The new ones, like ours, will heat with outside temps down to -20C, and as a result our heating oil consumption has dropped considerably - and we get air in the summertime. I am with Kurt - mini-splits are WONDERFUL.
KB58 wrote:
Installing them is straightforward............
Talk about scope creep (gee thanks guys!
) - I was about to be perfectly happy spending $260 on a cheap 12,000 btu unit from from Costco!
For a garage, do you think the efficiency of going with a 110 unit is really that big of a deal? It will only be running when I'm working out there/plan on working out there.
My garage is about 30' x 18.5' with 8' ceilings. The 12,000 btu seems like it may be a little marginal. I'm not looking for something to get it to 65 degrees in the middle of summer but 75 or 80 would be nice - think its worth going with an 18,000 btu system?
After you hook everything up, do you have to vacuum the lines or anything or just turn it on?
The online documentation is kind of lacking - I assume you have to run power to both the inside and outside units?
