It is currently Wed Jun 19, 2013 10:38 pm
 Post subject: sv1000 engine.
PostPosted: Sun Jul 22, 2012 9:57 am
I have found a sv 1000 engine for a good price. It will be going in my Amod car. Has anyone used one in a car before. I have tryed to find a dry-sump for it but had no luck. I may have to make my own. It will be about double the HP and torque over the 600 I have now. Chad
The beatings will continue until morale inproves!!
 Post subject: Re: sv1000 engine.
PostPosted: Sun Jul 22, 2012 1:33 pm
There's a couple on the net I have seen if you search long enough and then there's the "SUB 3 wheeler" http://www.sub3wheeler.com/
What 600 do you have now?
PostPosted: Sun Jul 22, 2012 7:59 pm
It is a 93 GSXR 600. It was kind of a pig back then and even more so now.Suzuki de-bored and stroked the 1100 and made the 750 and 600. It was rated at 80hp and 37 flbs. The sv is rated at 120hp and 75 flbs. It would be a big boost on a 900lbs car. my big concern is oiling. Some bike engines don't like being put in a car. Mine has done real good. I haven't had any problems. A guy in Knoxville used a ZX14 in his car and it only lasted a few races. He wasn't using R-comps either. My g-loads will be much higher than his. If I take the money and time to convert it over I want it to last. Chad
PostPosted: Sun Jul 22, 2012 10:32 pm
An Accusump will cure the oiling problems.
PostPosted: Sun Jul 29, 2012 3:32 pm
I tried to contact Sub3wheeler but they must not be around no more. Chad
PostPosted: Sun Jul 29, 2012 3:55 pm
Not surprising, not many radical, stupidly overpriced speciality vehicles make it in the market.
Should have been a $5000 kit for what it is, not a $50,000 kit.
PostPosted: Sat Aug 04, 2012 3:44 am
What are the dimensions for this engine (overall L/W/H)
PostPosted: Thu Aug 09, 2012 4:49 pm
I haven't picked it up yet. I do know it is narrower than the engine i have now. Chad
PostPosted: Fri Aug 10, 2012 1:15 am
I just remembered that Honda themselves built some V-Twin single seat sidewinder race cars specific to the race track they own in Japan (Motegi), I'm sure you can find them with that info.
http://www.gizmag.com/the-spartan-ducat ... car/20580/
PostPosted: Fri Aug 10, 2012 5:48 am
Now that is a sharp little car!
Expensive, but good looking.
PostPosted: Mon Oct 01, 2012 11:21 pm
No experience them other than on 2 wheels...
I've got a 2003 SV650S. Great all around bike, especially for commuting / track days with the typical basic upgrades..
73.4 hp / 47.2 lb ft
It's a lot of fun not having to downshift to easily overtake traffic while the guy you're riding with has to kick it down a gear or 2 to accomplish the same. :lol:
Not mind bogglingly fast by any means, but solid predictable torque all through the revs.
Btw, svrider.com has a ton of resources.
Here's a quick link to a non SV dry sump failure on a drag bike. :o
http://www.svrider.com/forum/showthread.php?t=134770
Hope it helps. :D
PostPosted: Tue Oct 02, 2012 1:19 am
Interesting, thanks.
I see that it's an accumulator/reservoir, so it depends on the oil pumping rate and how long the corner lasts.
May very well be a viable option to going into the crank cavity and putting a baffle in.
Noah
