romkasponka wrote:
Quality build.
The thing which I do not understand why you made rear end so long? It is possible to finish frame before differential and to mount differential outside the frame. Suspension arms rear members can be parallel to half-shaft and front moved more fwd. Dampers can be easily relocated with push-rods more fwd. All these things will reduce mass, polar moment of inertia and will make you race car more responsive to steering input. Rear end could be a little higher for diffuser. I hope one day I will be able to achieve the same build quality.
Good luck!
You make some good points, I wanted to keep the rear frame a little longer to support the rear wing etc. There is a ton of loading on the element I'm using It has a deep cord length so I want the frame to take the load not the body.
Also mounting the diff forward is keeping weight bias forward where I want it. Honestly there is very little weight aft of the differential.
It was also imperative to keep the drive shafts at an angle to the wheels as when they are straight on they develop a wicked vibration.
More to follow... been taking a week off the project to stop me from burning out.
Linz
