It is currently May 19, 2024, 3:06 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Reasons to go BEC
PostPosted: September 6, 2022, 12:16 pm
By the way, motorcycle drive trains have lash in them, not because of having straight-cut gears, but rather because they are constant-mesh dog-engagement style transmissions. The straight-cut gear pairs are always in mesh, and slide back and forth on the shafts, with large tabs (dogs) on the sides of the gears sliding into engagement with mating dogs on the adjacent gear pairs. There are large clearances between the dogs, and that is where the lash/snatch originates from.
Is there any way to cushion the dogs to lessen the lash/snatch in the transmission?
PostPosted: September 6, 2022, 12:33 pm
gto7419 wrote:
Ive put about 500-600 miles on mine this summer. I had awful oscillations with the original motor due to low compression. New motor went in and the issue is almost entirely eliminated.
I've got a 150hp 02 r1 engine.
kreb wrote:
Zombie thread here. I'm familiar with herky-jerky throttle action by virtue of driving a car-engined locost with megasquirt and ITBs. The owner has never gotten the occasional jerking action out of the car, which is both annoying and embarrassing. It's said above that a guibo will largely alleviate that condition, but what if you're running a chain drive in a mid-engined application. The chain is going to be short with very little potential for absorbing lash. Any feedback?
Are you running any sort of cush drive?
PostPosted: September 6, 2022, 2:21 pm
Not that I know of, looking at a donut in the drive shaft, but not sure yet I want to hack up the drive shaft to fit one. I would like to lessen the bang, when going into first gear.
PostPosted: September 6, 2022, 4:54 pm
There should be no bang if the clutch is fully released and the idle speed is not too high.
More pedal travel allows for more finese by the driver to ease engagement.
PostPosted: September 7, 2022, 12:36 pm
It's the typical clang going into first gear, I guess that everyone with BEC seems to experience.
PostPosted: September 7, 2022, 2:10 pm
It's true that that "CLANG!" is part of the BEC animal, but I've done 2 things that have helped lessen it.. First (and most importantly in my opinion) is to fab in a Giubo (aka 'rubber donut') into the BEC's driveshaft.. your bike transmission will thank you for this.. it will both help protect your bike tranny and greatly reduce that 1st-gear 'BANG!' that you'd otherwise get.. I originally built my Honda N600 BEC without a Giubo, and I hated it; hated that Bang!!-shifting so much that I tore the driveshaft out and fabbed in a much-needed Giubo- totally changed the driving experience, and I'd do it all over again 8)
The other thing I've done is a little cheesy, but it works.. I've cut two strips of Dynamat (about 4" wide by 12" long each), and I've stuck them on the driveshaft (like rings) at 1/3 intervals the length of the shaft (essentially offering a sound deadener in two separate places on the shaft).. I then installed a few zip ties on each of them to make sure they don't come flying off at high rpms.. These light, unseen strips really help absorb/ eliminate that awful clang that BECs suffer from..
At very least the Dynamat strips are worth a try- easy to pull back off if you see (hear) no benefit.. Both of my last 2 BEC projects are running both a Giubo and Dynamat on the DS with great success :cheers:
--ccrunner
Dean
1963 Volvo P1800 Restomod
viewtopic.php?f=36&t=19397
PostPosted: September 7, 2022, 7:10 pm
It's worth a try, did you have to grind down anything off the driveshaft, to fit the donut? Did you buy an off the shelf one and mod it for your motor?
PostPosted: September 7, 2022, 7:43 pm
The donut I used was just an off-the-shelf BMW/Saturn/Pontiac piece.. It's a hassle, but you'll need to make or have made an adaptor to go from your bike's output shaft, then the donut, then your driveshaft going toward the rear of the car (that is if you put the donut on the motor side)... If you want the donut on the rear end side, which may be easiest, then it's rear end mounting flange, custom adaptor (likely aluminum), donut, then driveshaft going forward. It's not that complex, but it must be done right and perfectly balanced as a unit; that donut/driveshaft are spinning right next to you the driver! (I put 3 separate DS hoops around my DS as I'm paranoid about having this thing grenade right next to me..
If it helps, a Saturn Sky/ Pontiac Solstice DS will have most of what you'll need (for the donut install), but you'll have to have it modded to fit your car of course.. In the above pic, most of the DS that you see was sourced from a Pontiac Solstice, just lengthened for my needs..
Fair warning, it's a bit of work and a hassle to fab in a Giubo, but in my experience, it's essential for a BEC
--ccrunner
Dean
PostPosted: September 7, 2022, 8:19 pm
Thank you, Sir, good info
PostPosted: September 10, 2022, 5:54 am
Well, I don't agree but the great thing about a good forum is we don't need to. :cheers:
PostPosted: September 11, 2022, 7:54 pm
No cush drive. Obviously you can induce oscillations with any manual car. The r1 will oscillate if you meet some conditions, but so will my c5 Vette.
PostPosted: September 11, 2022, 8:09 pm
True, but the consensus is that it's far more likely to happen in a BEC. I can invoke it in my mid-engine Seven, because first gear is good to 60mph, and has a light aluminum flywheel. A BEC has a long first gear as well, little or no flywheel, making it very easy to get into bucking even with an owner who expects it.
PostPosted: September 14, 2022, 6:57 pm
No disagreement - its definitely easier to do in a bec. :cheers:
