It is currently March 29, 2024, 4:55 am
PostPosted: May 7, 2017, 3:00 pm
Pros? Cons?
PostPosted: May 8, 2017, 8:23 am
Pro - you get reverse without hassles.
Con - you keep the weak link (the motorcycle clutch)
Con - you have to split the cases on the cycle motor to gut the trans.
Pro - you will likely never break the Audi trans
Con - the cycle motor will need a modified oiling system to survive lateral G's
Con - you will have to deal with cycle electrics (EFI?)
Con - (Pro?) you will have to develop header building skills
Pro - you will not need a big radiator
Con - you will need an oil cooler
Honey anyone?
PostPosted: May 8, 2017, 12:51 pm
Con - Guibo!
They fail.
Sometimes spectacularly, doing a LOT of damage.
Original quality parts are hard to find and expensive.
CV joint would be much better.
PostPosted: June 9, 2017, 9:50 am
The main problem I see is that you wind up with a fairly long distance between the front of the motor and the axle centerline. But bike engines are shorter and less bulky on top than car engines, which would let you tuck it into the firewall a bit more.
On the other hand, it's probably still shorter than a chain drive diff behind the engine, not to mention the forward lean of most modern sportbike engines is the opposite direction from the firewall.
The Audi diff is both bulky and heavy, but it'd be bulletproof, and there's a decent assortment of gears and final drives available for it. There have been lighter and smaller transaxles, but most of them are old, oddball, designed for engines with much less power, and not much in the way of gear ratio options.
