Build Using Harley Motor http://locostusa.com/forums/viewtopic.php?f=10&t=18936 |
Page 1 of 2 |
Author: | atengnr [ June 17, 2017, 7:21 pm ] |
Post subject: | Build Using Harley Motor |
Hello all. New here and just doing some early thinking. I would love to have a small car with a harley engine in it. Ive given this a little thought and was thinking that perhaps this could be done with a mazda miata? The morgan 3 uses the miata tranny and seems to have their own design coupling to the tranny from the motor. Would it be doable to purchase this coupler from morgan to adapt to use on s miata? Do tou all have more food for thought for me in terms of whats been done and how?? Thanks alot. Russ |
Author: | RichardSIA [ June 18, 2017, 12:08 am ] |
Post subject: | Re: Build Using Harley Motor |
As I recall Harley's have somewhat weak cases for that type of load. Chain drive to the rear might handle that but it's a long way to go. |
Author: | Sam_68 [ June 18, 2017, 4:19 am ] |
The Morgan uses an S&S engine, and the Morgan design originated with Pete Larsen's Liberty Ace in Seattle, so the bellhousing adapter is probably manufactured by S&S, anyway - I'd talk to those guys in the first instance, before trying to import from the UK (although Morgan may now have exclusive licence to the components). I'd have thought that the Hardly Dangerous motor would struggle pulling something as heavy as a Miata, though; it's comparable in power to the original 1.6 litre Miata, and we all know how limp the performance was on those. |
Author: | carguy123 [ June 18, 2017, 11:27 am ] |
Do a middle and then you only have to run a short chain & jack shaft. |
Author: | atengnr [ June 18, 2017, 2:27 pm ] |
Thanks all. What car for a mid engine? |
Author: | Warren Nethercote [ June 18, 2017, 2:47 pm ] |
Midlana or the mid-engine car nine, to suggest two. |
Author: | Bent Wrench [ June 18, 2017, 3:41 pm ] |
A proper Harley powered three wheeler would look like this. |
Author: | RichardSIA [ June 18, 2017, 5:22 pm ] |
Or, forward mounted engine and front wheel drive. Works for three or four wheels. If you are resorting to a jack-shaft all sorts of things become possible. |
Author: | BHRmotorsport [ June 18, 2017, 9:44 pm ] |
Looks like its been done.... Attachment: Screen Shot 2017-06-18 at 8.42.57 PM.png http://www.ridelust.com/harley-powered- ... under-wtf/ |
Author: | RichardSIA [ June 18, 2017, 9:51 pm ] |
I was thinking engine in it's normal orientation and behind the axle centerline. Not sure how they come out for length but should be fairly short. Is there a water cooled version? |
Author: | Bent Wrench [ June 18, 2017, 11:05 pm ] |
RichardSIA wrote: I was thinking engine in it's normal orientation and behind the axle centerline. Not sure how they come out for length but should be fairly short. Is there a water cooled version? Sure, find some drake cylinders! |
Author: | turbo_bird [ June 18, 2017, 11:29 pm ] |
I'm pretty sure the vrods are/were liquid cooled. They didn't do very well with the faithfull do to that, not sure if they even still make them. Kristian |
Author: | atengnr [ June 19, 2017, 7:14 am ] |
BHRmotorsport wrote: Looks like its been done.... Attachment: Screen Shot 2017-06-18 at 8.42.57 PM.png http://www.ridelust.com/harley-powered- ... under-wtf/ Anyone know how this was setup in terms of transmission and driveline? |
Author: | atengnr [ June 19, 2017, 8:35 pm ] |
OK all, so question for you. I am a reasonably accomplished weekend mechanic, former mechanical engineer, however, I have never welded, or undertaken a project such as I propose. Is this doable for a stubborn guy with the above experience? Thanks. |
Author: | turbo_bird [ June 19, 2017, 8:52 pm ] |
atengnr wrote: OK all, so question for you. I am a reasonably accomplished weekend mechanic, former mechanical engineer, however, I have never welded, or undertaken a project such as I propose. Is this doable for a stubborn guy with the above experience? Thanks. Well my biggest qualification was growing up on a farm, so if I can build a car, I think anyone probably can. Kristian |
