I had a 'less haste more speed' moment.
The steering post head (an aluminum machined part) on my iceboat fits over the steering post (a mild steel tube) and is located by a roll pin driven through both. The drilled hole through both head and post isn't right on the axis, so you need to orient the head properly when you drive the pin in. If you're in a hurry (...he said...) and orient the head 180 degrees out of phase, the entry hole lines up and the exit holes don't. The roll pin drives in until it bottoms on the misaligned hole on the other side, and you can't get a drift pin into the misaligned hole on the other side to drive the pin back out. Ask how I know.
I couldn't grip the roll pin well enough to pull it out (if that is even possible), so I sawed off the protruding end and tried to drill out the roll pin. It's made of hard stuff! I make occasional progress, but it's mostly a case of ruined drill bits. The beastie is installed on the iceboat, so I have to use a hand-held drill instead of my drill press, and I can't get high enough feed pressure or a low enough speed.
I have thought of going in from the other side with a big bit, to expose the other end of the roll pin to allow me top drive it out with a drift, at the cost of having to drill a new set of holes through the head and post. This would be structurally acceptable, but an everlasting indicator of my original screw-up.
Any thoughts? It's something of a priority for me. It's the last step in assembling my new iceboat, which has been keeping me away from my Locost build. The iceboat season is starting, and more important to this forum, I'd like to get back to making progress on my car.
(PS: it's a 1/4 inch roll pin, so space is tight!)
Warren
Build Log:
viewtopic.php?f=35&t=11601
