It is currently Tue May 21, 2013 10:17 am
 Post subject: Hooley Dooley, look at the welds on this ..
PostPosted: Wed Apr 25, 2012 3:26 am
As I consider welding just as a means to an end (sticking 2 pieces of metal together duh), welding otherwise doesn't get my attention until you see something extraordinary like this ...
http://www.build-threads.com/build-thre ... brication/
 Post subject: Re: Hooley Dooley, look at the welds on this ..
PostPosted: Wed Apr 25, 2012 8:31 am
Man, that is about the best looking welding I have seen. Craftsmanship at it's best.Fabulous!
PostPosted: Wed Apr 25, 2012 11:41 am
:cry:
PostPosted: Wed Apr 25, 2012 1:35 pm
The welding is impressive, but so is that shop!
PostPosted: Fri Apr 27, 2012 8:27 am
PostPosted: Sun Apr 29, 2012 12:21 am
Excuse me while I go throw a sheet over my frame to hide my shame.
Seriously though, that is amazing!
Build Log (not much there yet): http://lotus.reddeth.com
442e frame, 3.4l Camaro donor
PostPosted: Fri May 25, 2012 12:42 am
Pales in comparison of course but just for those of you who have a pre-conception of Chinese welding ...
PostPosted: Fri May 25, 2012 1:41 am
That looks like very nice work, Cheapracer. Sometimes I can get a very nice looking bead, but I can never be consistent at all angles around a tube, uphill, downhill etc.
PostPosted: Fri May 25, 2012 9:46 am
Cheapracer,
A question: in the first of your two photos, what happens in the inside joints of that short diagonal tube. Do you leave that side of the joint unwelded, accept long stick-out with MIG, or go back to it with Flux-core or some other process (TIG?) that isn't as access-challenged as MIG?
It's a practical question anticipating some of my own problem areas.
I too would be proud to to as well as your Chinese welder ....
Warren
PostPosted: Fri May 25, 2012 12:28 pm
do you mean a chinees welder or a man from china that welds?
i used to do gas like that and tig but it takes sooo long to do the prep work, but i am as lazy as hell now and just burn it in with the mig, what you get is what you get.
i see you stand like greyhounds in the slips straining upon the start, the games afoot, follow your spirit.
PostPosted: Sat May 26, 2012 2:17 am
It's all TIG'ed, unprepped other than basic descaling if required. Those diagonals are actually zinc coated as that's what was laying around* hence the white'ish colour. (*it's only a pre-production test run).
My own insides on diagonals I do with long stick out (MIG) without any problems although it helps if you're above the weld of course.
John;
He is a Chinese welder in China and even uses his own cheap/portable 220 volt TIG in preference to the factories 380 volt/3 phase TIG :-) He uses 1.6mm MIG wire for filler.
