This is one of those choices that you don't really know until after you do it, maybe evan a couple of years later.
The cheaper welder can help you out a couple of ways. It leaves you money for the things you probably aren't counting in the budget, various supplies, consumables, practice stock etc. When your trying to get your foot in the door so to speak, even if you buy a better one in a year or two, this money might not be wasted. What if you decide you also want a MIG for instance, then you need two tanks with different mixes, maybe you want a flowmeter, maybe, maybe it goes on.
It would leave you money to make an extension cord for the 220V from somewhere in your house that has it, like a clothes dryer or stove. That could cost a couple of hundred dollars, but would come in handy if you want to do work on site somewhere. Evan if your house doesn't have a 220V outlet, maybe we could make one with an extension cord.
The Eastwood has a deal where you can also get a plasma torch for $999 with the TIG.
So I would vote whatever looks cheaper and at least workable. Your going to spend a lot of money on a lot of things coming up and it's easy ( probably evan a little helpful ) to not think about all the little stuff.
Good luck and don't look back too much. There will be upsides in any choice you make.The downsides, just leave those behind ( don't look down! ). ( well maybe when you are parachuting, you should look down
