It is currently March 29, 2024, 1:55 am
PostPosted: September 17, 2019, 8:58 pm
I am bolting rubber torsion suspension onto a trailer that I am building and want (need?) to add crush tubes to carry the compression load from the bolts where they penetrate the rectangular tube frame rails. I am planning on using schedule 40 steel pipe for crush tube, but the selection of diameters is rather limited, and I'm reluctant to drill out the length of an undersized tube but otherwise will have a sloppy fit on one end at least. The internal diameter of a 3/8 Sch 40 pipe is something like 0.49 inches, and the ID of the next lower size (1/4 in.) is too small for a 3/8 bolt.
Any suggestions?
Warren
PostPosted: September 17, 2019, 9:34 pm
1/4 sched 40 pipe is .364 could very easily be drilled to .375 and then reamed .002 over or use a size "V" (.377") bit to finish.
PostPosted: September 17, 2019, 9:53 pm
I really hadn't thought about it. I would guess that the cross section of the tube should be greater than the cross section of the bolt being used. Buckling must be avoided. I don't think this will be a problem with a relatively close fit of tube vs bolt. Steel tubing (not schedule 40 pipe) can be bought from many different sources in various OD's and wall thicknesses. I've been fortunate to find the right sizes for reinforcing axle slices and trailer axles. I'm sure that a bit of searching for steel tube in various wall thicknesses should get you close.
Are you wanting to use 1/2" hardware? Looking at onlinemetals.com I see .75 OD Cold rolled with .12 wall is available. This gives .51 ID. the cross sections is larger than the 1/2 inch bolt.
https://www.onlinemetals.com/en/buy/tub ... eckbox=on#
PostPosted: September 18, 2019, 8:08 am
Thank you. I will do some more homework.
Thee other twist on my application is that I am galvanizing the trailer. Do I fit the crush tube loose and naked, or do I weld it in and galvanize it?
Decisions, decisions. :-)
Warren
PostPosted: September 18, 2019, 8:42 am
Personally, I would weld the crush tubes in place, then dip the frame. Zinc is very soft and if it gets in the ID, then chasing with an appropriate sized drill should be easy. Much easier than drilling an undersized hole, which is pretty easy itself.
PostPosted: September 20, 2019, 9:09 pm
Went with 1/4 sched 40 pipe and fitted the first crush tube tonight. I won't weld until I've fitted all eight. Picky work or what, but better safe than doing without.
Warren
