It is currently February 17, 2020, 9:35 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Car lift install
PostPosted: December 29, 2019, 7:30 pm
Done! Just need concrete.
PostPosted: February 14, 2020, 11:22 am
Online
Any more updates on this project?
PostPosted: February 14, 2020, 3:25 pm
Do you have the post base plates? If so, you might look at imbedding the anchors in the concrete as you pour. You can make a plywood template to locate the anchors. I have often used "L" bolt anchors of the right diameter. You can get them typically at Home Depot, Lowes or and good hardware store. I would guess they are at least 1/2" if not larger bolts. Have the bolts stop down in the hole just short of the bottom about 1".
This gives the best pullout strength. You can drill and place expansion anchor bolts. But it is a pain to sometimes get them to grab.
Good Luck!
Thom
PostPosted: February 16, 2020, 1:13 pm
Oh crap yes it's progressing. I paid a concrete company $1k to come in and pour the concrete and smoother. Then one of my Contracting buddies drilled the holes but the issue was that we didn't have a guide to mark the holes and we just did it with a sharpie which made some of the holes off. They weren't off very much but the bolt that goes through the plate in the Base is almost the exact size of the hole in the base so the drilled holes would have to have been dead nuts to work right. Yesterday I opened up some of the holes on the plate with a few burrs and mounted everything.
Today I plan on putting fluid in the pump actuating it and then plutting the race car on to check fit ( I'm hoping I can position the race card just right so that we can park under it and still clear the door when it opens). Because my wife now has to park in the center of the garage, I have to move my workbench otherwise our Explorer touches it. :BH: but that's okay since I have plenty of room around the edges. Speaking of don't make fun of how messy my garage is right now!!
PostPosted: February 16, 2020, 5:16 pm
I was going to how nice your garage looks. My garage looks 10 times worse. I wish I had a two post lift but no head room. I hate my scissor lift. Russ
PostPosted: February 16, 2020, 8:40 pm
Boom!!!
Lifted all the way and I can still open the door.... barely. I may make some custom mounting points for the car to get it exactly where a want it but it works for now.
PostPosted: February 16, 2020, 10:28 pm
I rain on parades, it's what I do.... Preface this with: I don't have a lift but would like to, but recently read on another forum that made me think.
A guy posted that he doesn't use his lift as much as he expected, but had planned to use it as you show it, for "storing" one car above another. He said that it ended up being a pain to go through the steps to use the second car: back out the "regular car", move it out of the way, get out, lower the car, swing the legs back, get in the car, back it out, and repeat on the way back. He said that after a while, it became enough of a process that he'd often just take the regular car since he was already in it.
OTOH, for servicing a car, or using it to pull engines, that's a pretty big perk.
PostPosted: February 16, 2020, 10:43 pm
A guy posted that he doesn't use his lift as much as he expected, but had planned to use it as you show it, for "storing" one car above another. He said that it ended up being a pain (for him) to go through the steps to use the second car: back out the "regular car", move it out of the way, get out, lower the car, swing the legs back, get in the car, back it out, and repeat on the way back. He said that after a while, it became enough of a process that he'd often just take the regular car since he was already in it.
We considering that the race car really never runs... no big deal. :D
I usually park one car in the front anyway since it's hard to work on the race car with two cars in there. Now I have much more room.
The big issue will be when I want to put another car on the lift. I have a three car drive way but that's at the front of the house. What do I do with race car in the mean time?? Push it all the way around the block to the front of the house?? Time will tell.
But the good news is that it will be up there most of the winter while I do some chassis welding and redo the wiring harness. Then I will take her apart and powder coar the chassis.
PostPosted: February 17, 2020, 1:14 pm
You'll only get in trouble if the race car decides to mark it's territory and drip on the Bimmer.
Oil isn't so bad, brake fluid is another story.
