The first challenge is to determine the required strength including safety factors. This is a very difficult task, if at all possible. Then and only then, can you optimize materials and sizes. Or you can just use existing builds as a reference. MV8's response says a lot. The "book" design falls short, especially when moving the spring/shock away from the upright. This is a known design weakness. Lower control arms in a book chassis take most of the load. The upper control arms, much less.
The video clearly overloaded the ERM (what grade?) beyond its rated capability. I think that if the loads applied were below the yield strength for the ERM, both materials would have reacted exactly the same. i.e. the same arc, droop, and the resultant permanent deformation. I am no expert on materials though.
