I came up with a filter-free drying system that worked really well. All it needed was a cooling coil from an old deep freeze! You plumb it into the outlet line from your compressor & positioned in front of the compressor's pulley/cooling fan, followed by an oil/water seperator, then into your tank. Plumb in another water seperator in the outlet line of yhour system (just before your hosae connector). It works like this: as you compress air, it gets hot, and it holds a LOT of moisture. If you can cool it before it goes into the tank (i.e., via the cooling coil), 99% of the moisture will condense out (it really works!) into the water seperator. Then the air goes into the tank. As you release the pressure some more (by releasing some of the air in the tank into the hose), the pressure (and temperature) drops again, and what little moisture still there will condense out into the second water seperator. What comes out the hose is absolutely dry and clean. My secondary seperator only collected about 1-2 drops of moisture per year, and there has NEVER been a drop of water in the tank. And, no filters to change! My cooling coil was out of an old deep freeze, and was 1/4" NPT in and out, just like normal iar fittings. Couldn't be easier
