It is currently January 17, 2019, 3:53 pm
Post new topic Reply to topic  [ 95 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
 Post subject: Re: RebelRouser RT
PostPosted: July 30, 2018, 2:11 pm
Back from motorcycle swap meet and scored a Harley 18x10 rear rim.
TomyJcreations @ Pinterest
PostPosted: July 30, 2018, 5:38 pm
Don't forget the fuel tank. I'd hate to see you paint yourself into a corner.
PostPosted: August 4, 2018, 10:39 pm
I am going to take the easy way out and use the Rebel tank between the seat and the steering column and maybe wrap the frame around it on the sides?
Would love to have a tank like this custom one.
PostPosted: August 5, 2018, 6:43 am
Ah, I get it now, Honda Rebel rousing! :cheers:
PostPosted: August 5, 2018, 9:35 pm
Over all design getting closer, rear shock needs a more lower mounting point, and the front shock? I just might take the easy way out and go vertical. My plan so far is to sell this before it is finished with or without the 250cc engine/ parts bike. The new reverse trike "Shenanigan's" will be sorta a kit, drawings to the engine compartment.
PostPosted: August 8, 2018, 10:27 pm
I'm pretty sure the shocks will go this way?
PostPosted: August 23, 2018, 12:27 pm
Having design problems with the lower frame, needs to be wider in front, And someone wants to chat about building a electric RT for he and his wife...
PostPosted: August 23, 2018, 5:19 pm
We like to solve problems if you'd like to share the specific issue(s).
PostPosted: September 3, 2018, 12:37 pm
The welders in my area will not give me flatness so I will make the frame rails one piece which means the front end will be wider, OK I can live with this so now I bought the steel and am cutting new control arm mounts.
PostPosted: September 19, 2018, 1:59 pm
Cut new one piece frame rails,
PostPosted: September 25, 2018, 6:07 pm
Any thoughts about rack and pinion center steer?
PostPosted: October 5, 2018, 2:33 pm
Maybe...
PostPosted: October 5, 2018, 5:45 pm
To minimize bumpsteer, consider bell crank steering, where one leg attaches to the tie rod fwd of the steering shaft and the other attaches behind it. If the toe links need to be shorter than this type of steering would allow, to match the arc of the toe attachment on the spindle, look for a center tapped center pinion rack. The ends bolt down to the chassis and the middle slides back and forth.
PostPosted: October 8, 2018, 11:23 pm
Upper frame rails are flat, square and ready for the welding, with the brackets for the control arms...
PostPosted: October 17, 2018, 2:12 pm
Tack welding done on the frame rails, now a fixture for alignment of the 18 degree uprights and tie in the swing arm...
