It is currently March 29, 2020, 2:14 am
Post new topic Reply to topic  [ 1161 posts ]  Go to page Previous  1 ... 74, 75, 76, 77, 78
PostPosted: November 24, 2019, 8:17 pm
Compression testing results
Dry:
CYL1: 120
CLY2: 110
CLY3: 100
CYL4: 120
Wet: they all went up between 180 and 270 but I guess that depends on how much oil I put in. Regardless its pointing to the rings not holding compression. Possibly from running rich and washing the cylinders.
I didnt see any material in the oil when I drained it but I could be in the baffle area so I will need to drop the pan and look further.
I will do leak down test next.
PostPosted: November 28, 2019, 7:36 pm
No bearing material in the oil pan!!!!!!!!!!!!! Yeah!!!!!!!!! I'm going to put a borescope down inside spark plug holes and up from the bottom to see if there's any scoring on the cylinder walls.
PostPosted: March 14, 2020, 3:19 pm
Well she started up!! That's a big relief. I think now I am going to drain the coolant and see about modifying the radiator to make it a dual pass. I'm a see if Saldana Racing can quote a new one too. Not quite sure what to do about the cooling problem I figure I would go there next.
PostPosted: March 15, 2020, 7:56 am
All your pics are gone. You can re-add them the same way you did when posting them.
You've had a ton of advice on cooling from a lot of different people with these cooling issues. Did you implement the air-oil cooler and high amp fan? You could always keep the little spal and use it on another project later as a secondary such as a tow vehicle. Maybe you should just turn down the boost until what you have is reliable.
PostPosted: March 15, 2020, 12:52 pm
Yes I did install the high temp fan and the oil cooler. Not the prettiest install though. I did run it on the track but it seem to have little effect along with the higher temp fan. Now I need to start looking at other parts of the cooling system.
Thoughts are:
1) the radiator has stagnant flow causing heat flow (pretty sure)
2) the radiator isn't large enough
3) flow issue (pump or tubing size)
I dont think turning down the boost (pretty low as it is) will help since I can get her to over heat in the garage just getting on the throttle. I also need a way to collect better data. Open to more suggestions.
PostPosted: March 15, 2020, 2:07 pm
Post pics. Pretty doesn't matter.
I went back enough to see you put in a high amp fan.
I can make most any car overheat in a confined space. Yes, boost is directly proportional to the heat generated.
What size are the coolant pipes?
Is there a bypass circuit for when the stat is closed? There should be minimal bypass because it allows coolant to bypass the radiator.
How much boost are you running? How much hp?
When you overheat, what are the temps when it starts flowing into the overflow?
How long will it idle without overheat from ambient?
What temp do the fans come on?
Are you monitoring oil temp also?
Where are you taking temp measurements?
What ratio gycol to water are you running? The more glycol, the lower the boiling point.
What is the timing set to?
Too lean at idle?
Feel the radiator core as it warms up. Any cooler spots or is it warming evenly?
Restrictions in the pipes can be felt as it warms up as differences it surface temp.
CO2 check the coolant for bubbles can show if the head gasket is failing and the boost is over-pressurizing the coolant system, causing overflow.
