Lleksam wrote:
LOL Thank you, all info helps, and sorry you lucked out maybe tonight
I have a set of 60mm rollers in steel for that tube roller so will get started as soon as i find some thinner 60mm tube 2.5 is a little on the heavy side .... shame realy i have 10 6mtr lenghts here
Steve
I don't think 2.5 is that big a deal unless you are going racing and desperate for weight. Look at the advantages, solid feeling, vibration absorption, suspension shock absorption, no doubt about welds, smoother rolling curves etc. as well as it's going to hold together for 20 years. I think you are convincing yourself for the wrong reasons.
On rolling which I do myself, I weld a 25mm tube 'T' piece on the end of each tube and set it to the horizon and keep it there by eye through the process steering like a motorcycle to prevent twist, works well. I always thought you could sit a spirit level on the bars too and watch the bubble but haven't tried it as my rolling machine has a nice easy to see horizontal edge to line up the handlebars with as the tube rolls through.
