I've seen bellhousing which mate a Ford 2.3L duratec to a VW transaxle. This sounds like a nice way to setup a mid engine RWD car. The problem is that I don't have a clue about VW transaxles. I've also looked at
www.mendeolatransaxles.com for some aftermarker/upgraded setups (quite expensive). As I understand VW has both IRS and swingarm transaxles. I'm interested only in the true IRS ones.
How much torque can I expect the stock VW transaxle to handle reliably? Bus transaxle?
How does the shifter linkage work?
How expensive are axles? What variety of hubs can I use with VW axles? Where can I get upgraded axles? Can I buy or easily build axles to fit other hubs?
How does the axle avoid binding with suspension travel? Does the splined end at the hub have a slip joint?
Where are good sources for the bellhousing/clutch? I haven't been able to find any prices.
The Mendeola transaxles are setup for offroad and sandrail use. Therefore they have very low gearing. What are the ratios in a stock VW transaxle? I assume the ratios depend on the donor vehicle.
I've done quite a bit of web searching, but I was hoping there was someone on the board with more expertise. I'm considering building a mild mannered car with a stock VW transaxle and a stock 2.3 Duratec. This should let me see how well I like the setup before I drop the few thousand on an aftermarket transaxle.
Many thanks
-Andy
