well i don't know how you did it without an adapter to actually bolt the rotary engine to the vw bell housing,
the vw has a register around the rim of the bell to centralize the motor.
the mazda engine has dowl pins to locate it in the mazda trans.
so unless you have some magic glue thats not possible.
as for the clutch i doubt if the mazda clutch will even fit inside the vw bell housing.
we havent even considered the starter location yet.
as i have stated previously, there are only two ways to connect a ford 4 cylinder engine to a vw or hewland trans.
the formular ford regs state that the original flywheel must be used, this requires the ford flywheel to be retained, that in turn requires that the ford clutch is retained the clutch center spline is somewhat erelavent due to the depth of the adapter needed to reach over the clutch and convert the bell housing pattern from ford to vw these vary dependant upon the manufacturer from 2 1/4" to 3 1/2".
the input shaft of a hewland is a special part and was available in several lengths to suit the adapter spacing, this will interchange with the stock vw input shaft as far as the trans is conserned, most are no longer available since the demise of mr. hewland, this also requires the use of a special spool to allow the clutch release bearing to operate the ford clutch. this setup uses the ford starter on the engine side of the flywheel.
the alternative method, used by the sand rail community is using an adapter fom someone like kennedy or esslinger which uses a thick aluminum plate with the correct bolt pattern for the ford, including the dowls, on one side and the vw pattern and perifery register on the other. then they have a vw type flywheel with a special center that will bolt to the ford crank. then the use of a vw clutch that carries the same spline as the vw input shaft to complete the install. this setup uses the vw starter on the transmission side of the flywheel.
so no you cannot just change the center of the clutch plate and bolt it all together.
