Hello forum,
I have been reading this forum for a great many months; it has been a great resource to me.
I am designing/ building a single seater, 2f1r "reverse" trike. It is "F1 inspired," utilizing a "recumbent" seating style, with total height < 36in.
I will be using an R1 as a donor, while fitting a larger back tire (planning on stealing the "boat anchor" and "jacktube" idea from Wyked's three wheeler)
I will spare you any more details until the build diary; i just aquired a shop, and am outfitting it presently. I am hoping to commence building within the end of the month.
ANYWAYS!
Here is my lingering concern:
I have designed a suspension which, frankly, is very similar to (with the exception of longer a arms) the locost front end, with some adjustments made to compensate for the longer arms, and increased propensity to roll from the single back tire. But that's all being thrown on its ear because:
The rear roll center, -because it is a single tire, the rear RC is set static at ground level. However, as currently designed, my front roll center is a few inches ABOVE ground. - That being said, i have come to find out there are a few parameters i must stay within for best results, namely,
A. The front/rear RC axis should ideally slope downward when moving from back to front.
***see below
B. The RC for either front or rear should not be below ground.
However, i have read that there might be an exception to parameter A above, namely, that the relative height of the front and rear roll centers are not/should not be take in respect to ground level, but rather, in respect to the "mass centroid axis." wherein, the slope of the RC axis should = Slope of the mass centroid axis, which is the mean slope of the
sectional COG points for the entire vehicle.
OK
so, if A,B are true, and rear RC is constant at Ground, then i am currently outside of my design parameters, with front RC > rear RC.
However, if this mass centroid axis thing is the case, then i am probably ok, insomuch as my design involves a "lifted" front nose, which will have a sectional COG @ aprox. 15" above ground, as opposed to the rear sectional COG which is likely closer to 12" above ground. -- if the front COG is 3-4 inches higher, my front RC can be too, or at least that's the reasoning....
Finally, if in fact i am outside the design parameters, and the mass centroid stuff is baloney, then, it seems my best bet is to set the front RC at 0" or ground level, by doing something that just feels wrong; making the a-arms parrallel. (i could, however still make them unequal length, right?)
A design of simillar charachter is the "scorpion P6" located Here :
http://www.scorpionmotorsports.com/-this seems to have parrallel a-arms, as does (if i'm not mistaken) the "indycycle", one of the first 2f1r "indy inspired" reverse trike.
HOWEVER, the t-rex seems to have unequal length, non-parrellel a-arms.
thoughts?
