I think Nick was kidding about the voting thing and support of Cheap's conclusion.
I think we are not considering that at lateral loads of this level would result in roll, meaning naturally some camber gain or less lost compared to the rear. While we talk about front transfer and rear transfer, there is also diagonal, since the cg is between the ends rather than on either end, so the inside is transferring to the outside front and the rear.
I've driven the 1f2r atvs that were banned in the 80s, trike converted touring bikes, and even taxied heavy aircraft. They all understeer except for the atv, which would throw you long before you got to that point.
Justin made my point that a blanket statement shouldn't be made, even if the source of the statement is well known.
From this Road and Track test of the Trex 1400:
http://www.roadandtrack.com/car-reviews ... -rex-1400r"Even with the relatively small 205/45R-16 tires up front vying with a monstrous 295/35R-18 rear (which is actually equivalent to two 147.5-mm tires) the front provides way more grip than the rear could ever wish for, making for a playful oversteer-prone design."
Regarding reverse trikes in general, I also found this article where a fellow tested a variety of machines:
http://www.telegraph.co.uk/motoring/new ... -test.html
