It is currently April 25, 2018, 8:02 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
PostPosted: June 17, 2013, 2:08 am
I have been working on this for a while now.
Yamaha R6 - approx 130 hp at 13,500
10" SCCA Formula 500 wheels - 18" tire od.
Chain drive VW Golf differential with inboard brakes
Hope to run with ICSCC (International Conference of Sports Car Clubs) in the Pacific Northwest or just track days.
Skayt'R6 (skate - r - 6) - any better thoughts on a name????
I should have the frame tacked together by the end of next week (baring any further setbacks)
JMR
Forgot to add -- approx 86" wheelbase and 66" overall width (56" rear track and 58" front track)
File comment: Frame pieces on the "table" (2' x 8').
2 front tires on the lower shelf.
File comment: Rear hub with wood "bearing" in a wheel for mockup.
File comment: Differential carrier with inboard brakes.
File comment: Front spindle assembly jig
File comment: All stuck in a 10" wheel.
File comment: Front spindle, hub and brake parts (4 piston Wilwood caliper on a 7+" rotor.
http://WWW.TRICKSOLUTIONS.COM
PostPosted: June 17, 2013, 9:26 am
[Hope to run with ICSCC (International Conference of Sports Car Clubs) in the Pacific Northwest or just track days.
How about "F...ing Fast". That thing is going to be wild. Love your spindles. Russ
PostPosted: June 17, 2013, 12:11 pm
Very cool build. Look forward to it. You do such nice work.
I fondly remember Conference racing. Raced FF from 83 to 87; SIR, PIR and good old Westwood. Were you around in those days?
Martin
My build log:
My build video:
https://vimeo.com/143524140
PostPosted: June 17, 2013, 12:25 pm
Kartracer, interesting build! Keep posting progress. Love your creative solutions.
Cheers, Tom
PostPosted: June 17, 2013, 12:41 pm
Thanks for the comments!
I moved from Southern California in 2005. The Superkart and I did PIR, SIR, Bremerton, Spokane and lastly The Ridge once we were here. Sold the kart last year. The Ridge is a very neat track.
JMR
PostPosted: June 17, 2013, 5:10 pm
How long does an R6 last at 13,500 Rpm?
PostPosted: June 17, 2013, 6:21 pm
A friend of mine, Rick Goodwin, built a number of cars which I believe he called FSR's for Bill Huth of Willow Springs Raceway. The prototype has been thrashed for 2+ years and has the same engine.
Video of Eddie Lawson driving one can be found here: http://www.youtube.com/watch?v=54C8i9acRaY
They are basically karts, no suspension, running Formula 500 road race slicks. Flat shifters and a roll cage of sorts have been added.
JMR
PostPosted: June 17, 2013, 7:19 pm
That's a confusing course at times. Good video
PostPosted: June 17, 2013, 10:02 pm
Yo Kartracer-
Interesting concept, pics of the bits you built so far look great. Please keep us posted on progress, I wanna watch this one!
PostPosted: June 18, 2013, 1:04 am
Thanks Tom, JDK, Carguy and mgkluft.
I ran Streets before they softened the hairpin turn (4?) in my Superkart - 1:19's in 2005. A couple of bumps are still bad but the banked bowl on the back of the course really pulled G's. I think the course is more fun backwards.
I will post progress.
Welded the lower frame rails that will be hidden by other tubes, added a temporary brace to position the rear roll hoop, tacked the front and rear roll hoops and the 4 cockpit side bars. . Engine first fit tomorrow.
JMR
PostPosted: June 26, 2013, 9:19 pm
Made a lot of progress on the new project this past week.
JMR
PostPosted: June 27, 2013, 7:10 am
Nice! What rack are you using? How wide? How much travel does it have? My rack is a latest rage, 8.5", two inches total travel. I'll be making the tie rod arms shorter on the spindles for a greater degree of turn, but I think my effort may be excessive. I have one inch of travel (to the stop) for 360 degrees of steering wheel rotation in each direction.
PostPosted: June 27, 2013, 11:16 am
The rack I am using is from this company http://www.desertkarts.com/item80862.ctlg Drawing and ratio shown when viewed. Chinese knockoff of a Stilleto rack. Play seams excessive so I will probably either remachine or make a new housing after I get the car running.
JMR
PostPosted: June 28, 2013, 5:07 pm
You have over twice the travel, but a quicker ratio, so maybe my effort won't be too bad. I can always get a different rack later. My rack was from Taiwan and has no discernable play from what I can tell without a dial indicator test.
I have an electric reverse like Fred in his JZR, so the turning circle needs to be pretty tight.
PostPosted: November 26, 2013, 10:47 pm
Some updates and a couple of "tip's" for building headers.
File comment: Headers in a fixture. I have previously used a hose clamp with 3 holes drilled in it. I can tack weld thru the holes with my TIG.
File comment: This time I used 3 pieces of feeler gauges (.005 or so) and 2 hose clamps.
Works much better.
File comment: I laid out a degree pattern on a board to improve the accuracy of cuts on U bends.
File comment: Me in the car! Right front at full bump and left front at full droop (2" delta)
