john hennessy wrote:
o we still haven't solved the problem of getting the drive shaft under the seat or which i prefer, around the side of the seat with a diff in the middle of the car?
John
yes, i agree; running the driveshaft/diff
under the seat will definitely not work,
the seating position (and its effect to the center of gravity) would be uncomfortably high
i think i basically solved the problem with the use of a offset IRS carrier (actually its a Ford Explorer IFS unit)
i crawled under my yardgoat (96 Exp sport 4x4 with snow plow & scrape box)
here are some basic dimensions of the axle;
the Exp uses "standard rotation" R&P gears , so as a IFS it is actually running on the weaker "heel" side of the gears ...
if used as a IRS it would run on the "correct" side of the gears.
this axle is designed to deal with the torque of a 245 ftlbs / 205 hp 4 liter V6 engine (and a low gear transfer case),
so it should be fine behind a less then 100 ftlb / 200 hp bike engine
the only potential problem i can think off would be a possible front pinion bearing "splash-oiling" issue,
with the ring gear not running in its intended direction
(probably not a huge issue on a "low pinion" axle design)
