RebelRouser RT http://locostusa.com/forums/viewtopic.php?f=18&t=19462 |
Page 3 of 9 |
Author: | TomyJ [ October 17, 2018, 2:18 pm ] |
Post subject: | Re: RebelRouser RT |
Attachment: Bellcrank Yamaha R1-08-07 $13.41.jpg Miatav8,MstrASE,A&P,F wrote: TomyJ wrote: Attachment: Rack and Pinion-center steer.jpg Any thoughts about rack and pinion center steer?To minimize bumpsteer, consider bell crank steering, where one leg attaches to the tie rod fwd of the steering shaft and the other attaches behind it. If the toe links need to be shorter than this type of steering would allow, to match the arc of the toe attachment on the spindle, look for a center tapped center pinion rack. The ends bolt down to the chassis and the middle slides back and forth. |
Author: | Miatav8,MstrASE,A&P,F [ October 17, 2018, 6:46 pm ] |
A bell crank is just an arm on a rotating shaft. |
Author: | TomyJ [ October 18, 2018, 1:23 pm ] |
Attachment: RT build coil overs.JPG I hope to have a coil over shock lay out close to this with bell cranks... I think that I am not explaining myself clearly, sorry...
Author: | tonico [ October 19, 2018, 8:43 am ] |
What front spindles, brakes, etc are you using TIA |
Author: | TomyJ [ October 20, 2018, 3:32 pm ] |
tonico wrote: What front spindles, brakes, etc are you using A quad sim. to Can-Am
TIA |
Author: | TomyJ [ October 20, 2018, 3:37 pm ] |
Attachment: HPIM5747.JPG Making fixtures for the upper and lower rails to be welded with the 18 degree uprights AND the swing arm which I am not happy with the fit of the rim...
Author: | Miatav8,MstrASE,A&P,F [ October 21, 2018, 5:44 pm ] |
TomyJ wrote: Attachment: RT build coil overs.JPG I hope to have a coil over shock lay out close to this with bell cranks... I think that I am not explaining myself clearly, sorry...No problem. The fewer the words, the more difficult it is to read skill sets. |
Author: | TomyJ [ October 25, 2018, 8:20 pm ] |
Attachment: HPIM5773.JPG Attachment: HPIM5772.JPG Fixtures are welded and installed for fit, need to trim a little more for the 18 degree uprights, then the lower rails control arms , and then the swing arm mounting brackets...Add fixture- these will keep the rails straight and offset for the control arms designed in...
Author: | TomyJ [ October 28, 2018, 8:29 pm ] |
Attachment: HPIM5789.JPG Attachment: HPIM5790.JPG Attachment: HPIM5791.JPG Scored at the motorcycle swap meet today, new swing arm is about 2" wider than the first one giving me more room for chain and disc brake, not to mention a fatter tire and taller...
Author: | TomyJ [ October 30, 2018, 2:06 pm ] |
Attachment: HPIM5799.JPG Attachment: HPIM5800.JPG Attachment: HPIM5802.JPG More mock up...
Author: | TomyJ [ November 1, 2018, 10:46 pm ] |
Attachment: HPIM5797.JPG More mock up...
Author: | TomyJ [ November 2, 2018, 1:44 pm ] |
Attachment: 2018-10-29-Seat fit.JPG I really do not like this seat?
Author: | TomyJ [ November 6, 2018, 12:58 pm ] |
Attachment: seat_by Mustang-for_harley.jpg Ohhh Yaaa!
Author: | TomyJ [ November 8, 2018, 1:45 pm ] |
Attachment: General_Gmax_RS_255-40-18.jpg Attachment: HPIM5839.JPG Attachment: HPIM5838.JPG The rear rim hub was to wide and causing problems, and just so happen to have another at the local Harley shop, for cheap I got this, Now mock up the chain and change the tire, 250-40-18, maybe? NOT!!! 215-35-18 enough for chain adjust...
Author: | TomyJ [ November 10, 2018, 9:14 pm ] |
Attachment: HPIM5844.JPG Attachment: HPIM5845.JPG Attachment: HPIM5843.JPG OK, This is the route I am going with the tire as wide as the rim, this will give me more room for the chain with button head bolts...
Page 3 of 9 | All times are UTC - 5 hours [ DST ] |
