It is currently May 30, 2020, 8:17 am
PostPosted: August 10, 2017, 1:13 am
Have the bones of a Laballa frame/kit - need info...
The front a-arms have RH 5/8-16 weld in inserts & the front suspension pod (subframe) is already set up w 3/8" holes in the brackets. Not finding much in the way of 3/8" by 5/8-16 Heim or rod ends - I'm thinking maybe to drill out brackets for 1/2" instead. Any body want to weigh in? Brackets are about 1-1/2" ID so maybe rod end w rubber bushing instead? I'll post pics if anyone wants a visual. Going to start to mock up chassis to put under a classic mini body. Have an MR2 donor out there. Accomplices want to do FWD Honda or RWD 6spd DuraWhatever in the Mini body. I plan on at least getting the Laballa frame rolling so someone will make a decision & trade me something I can use
PostPosted: August 10, 2017, 2:11 am
Is there enough room between the brackets to put high misalignment spacers in with the rod ends? There are high misalignment spacers available to bring both 1/2 and 5/8 ball bores down to 3/8.
PostPosted: August 10, 2017, 9:51 am
^^^^^^^^^^^ This ^^^^^^^^^^
I have on more than a few occasions used sleeves or stepped spacers to enable the use of larger bearing rod ends with smaller hardware.
