davew wrote:
" Ackerman is the same as a Chevy S10." The S-10 came in three wheelbases and used the same spindle on all three. Plus the S-10 spindle was a carry-over item form the older GM "B"-cars. So there had to variation with the WB changes but the spindle designed in Ackerman was consider sufficient for a lot of different WB's. Plus to add to the comments, the Pratt-Miller Vettes run as high as 200% Ackerman on some tracks.
As long as you are in the ballpark, because it would be hard to say one size fits all!
Also, I don't think any s10 with 2wd spindles had a rack and pinion, just 4wd. Converting to a rack changes whatever it was with a steering box linkage. The popular stalker steering arm shortening changes it further.
Ford IFS
