It is currently April 16, 2024, 12:11 am
PostPosted: March 29, 2016, 12:38 am
I could use your help sourcing some decorative aluminum..
I'm working on a 63 Volvo 1800, and it has a cool retro vibe with the OEM aluminum dash veneer.. Trouble is, I'm going to change around the switches a bit, so I can't use the pre-drilled stock bits.. I really like the look, so I'd like to come as close as possible to replicating what Volvo did..
So, in your travels, have you ever tripped over a source for aluminum sheet that looks like this? It's very thin and malleable.. I'll swap my upper and lower faces if I can't get an exact match, but I'd like whatever I sub in to have a similar look..
thanks guys :cheers:
--ccrunner
Dean
1963 Volvo P1800 Restomod
viewtopic.php?f=36&t=19397
PostPosted: March 29, 2016, 9:51 am
Don't know where to get it but it was also used in some BMC products, if that offers any clues.
Warren
PostPosted: March 29, 2016, 10:39 am
What you're looking for comes under the general category of "textured architectural metals" and there are a number of companies who handle them. A reference to one US-wide company with locations all over is included below. If you live near a big city, that city is likely to have at least one supplier who carries this type of product.
My suggestion would be to locate several and send them a photo similar to the one you've posted here. They may not be able to match it exactly, but probably have something similar. You'll likely have to buy a sheet, but some suppliers cut into half sheets or 1/4 sheets. There are several of these companies in the USA. I recently matched a pattern from the 1960's. They still produce it today!
Good luck,
One architectural metal supplier ==> http://www.mcnichols.com/products/desig ... ed-metals/
PostPosted: March 29, 2016, 11:54 am
Thanks guys :D
Used your exact language Lonnie, and came up with a great site- http://rigidized.com/samples.php
No exact matches (didn't think that was likely), but they have lots of cool choices.. I'll dig a bit more and see if I can buy direct or find a distributor..
Exactly what I needed.. thanks again :cheers:
--ccrunner
Dean
PostPosted: March 29, 2016, 10:27 pm
I'm a bit late... But... McMaster Carr might have something. A quickie search came up with this stuff:
http://www.mcmaster.com/#tread-plates/=11r9mg0
Maybe?
PostPosted: March 29, 2016, 11:57 pm
you might want to try making your own using a woven mesh and stamping an aluminum sheet. Take a look at http://www.mcmaster.com/#steel-mesh/=11raqdt
This is what the mesh looks like:
Walt
