I looked at that route. But, considering that I don't have a "donor" per se (rather, a collection of stuff from a bunch of cars, mostly Ford...except for the steering column & rack), it would have been tough. Plus, a huge volume of stuff was dedicated to the ECU (no longer used), the fuel injection (not me - got Webers), dozens of sensors (do I really need to know what the torque converter temp at stall speed at a given RPM, altitude, throttle setting, etc. is? Uh....no.), etc. So....I'm going to go with an aftermarket hot rod harness, probably a 14-circuit or something like that. They're plug-n'-play into my steering column, everything is color-coded AND labeled every foot, come with the fuse panel (with all relays & fuses in place!), and use heavier-than-stock gauge wire. I've seen these on the 'net for as little as $150...I couldn't even buy the wire for that. And, not that my time is worth much, I don't have much of it either, so this is the simplest option.
Another consideration is that all of my '80's vehicles are starting to have problems in their original harnesses. I'm finding a series of failures inside otherwise perfect-appearing connectors, and the wires near them, in my Porsche 944 and Fiero GT. They are a REAL pain to track down, as even if you separate the connector, things look good inside...but they can be bad, or worse, intermittent. Given the extensive "modifications" a lot of builders are having to make to their harnesses anyway, trouble-shooting could be problematic, to say the least.
Just a thought....
