I've been largely ignoring my ground wires up until now, both when I was stripping down the harness and when installing/modifying the harness to suit the Seven. I've got all the colored wiring (wires of color?) done (yeah, right!) and am now focusing on the black wires.
I welded a tab with two bolts to the frame under the scuttle, and mounted the two "ground junction blocks" there. (I made up that term...the piece with five black wires coming out and a tab to bolt it to the frame.) Then I just run all the black wires from various components to one of the wires. For components with tiny 18 (20?) gauge ground wires, I might combine two into one of the junction block wires, but for the most part every component gets its own wire...there is no shortage!
I have three questions/concerns:
1. Where does the battery ground strap connect to the engine? I suppose it doesn't matter too much, but I'd rather stick with the stock location to be on the safe side. I expected it to be on the block, but I don't see any obvious places where it was. I found some references to the back of the head, but couldn't find any precise references, and again, no evidence. I suspect this one, lonely bolt on the right side of the bell housing, but I really would not expect it to be on the tranny. FWIW, this is a '93 Miata.
2. There is one large ground wire with an eyelet terminal at both ends. I think it's around a 12 gauge wire. It's about 4 feet long, and has some other grounds tapping into it. Does this wire go somewhere critical, or is it just a big, fat ground trunk for other circuits?
3. On the engine harness, I put all the grounds under one bolt. This includes the black grounds, and the black/green grounds. I think this is a mistake, and would like some feedback. I'm concerned that the black/green grounds are signal grounds (right?) and that voltage from the regular grounds might overwhelm the signals. Is that a valid concern? If so, how isolated should they be? Regrettably, I don't have photos of this section prior to my changes, and haven't found photos of this online.
Thanks in advance for any tasteful replies.
-dave
Visit my
[Locost 7 build log]
