It is currently January 22, 2019, 12:32 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: September 24, 2016, 2:04 pm
Bent Wrench wrote:
My machinist friend is convinced that Wilwood makes "show" brakes.
He uses a lot of bad words when I take him Wilwood parts to work on.
So making good looking brakes is a bad thing and this is based on... what?
PostPosted: September 24, 2016, 2:27 pm
BBlue wrote:
Tom, I read sections of the book years ago. As I recall, he described three types of valves, constant percent reduction, pressure limiting and the type you describe. Wilwood describes their valve as giving up to 60% reduction of pressure. That's all. To me, that sounds like a constant reduction valve, the least desirable type. I suppose we will never know, unless some curious soul sets up a test rig, measuring input and out pit pressures across a wide range of pressure.
Bill, here's Tilton's explanation. It's consistent with Puhn's text:
Hmm, for some reason I can't copy/paste the url. but if you go to Tiltonracing.com, under the Technical tab, click on Installation Instructions, and under Brake Accessories you'll find a line item for Brake Proportioning Valve that will bring up a pdf.
Hope that helps.
Cheers, Tom
PostPosted: September 24, 2016, 4:13 pm
Hope that helps.
Thanks Tom, I hope the Wilwood item is the that type.
Bill
PostPosted: September 25, 2016, 2:14 pm
I swapped the calipers yesterday and I think it's going to work out perfect. It feels a lot better and I could get the fronts to lock, pedal pressure it a little greater but it was pretty light to start with. The next track day will tell because multiple +100 mph stops and tough to re-create on the street. But I love the Nocost solution to the problem.,
Thanks for everyone's help
Graham
