It is currently January 17, 2019, 12:37 am
PostPosted: November 3, 2017, 10:09 pm
Watch this video if you would like to take a crack at making your headlights from scratch.
[youtube]https://www.youtube.com/watch?v=A66iw8P5NQ4[/youtube]
Oh YouTube. Making me add one more thing i want to do to make my car.
I wonder if project Binky knows about this. lol
-STu
My Build Log
PostPosted: November 4, 2017, 1:26 am
Thanks for the link. That was really neat!
Bill H
Winnipeg, MB, Canada
PostPosted: November 4, 2017, 6:33 am
Probably didn't have have a cheap & easily available pressure source that would work as well as a grease gun.
EDIT: This was supposed to be in answer to Lonnie's Post! I don't know what's going on with the forum, but I posted this at about 4:30pm CDT! WTH?
PostPosted: November 4, 2017, 10:48 am
Lonnie-S wrote:
It was nice, but I wonder why he didn't use a more friendly fluid like water?
Probably what Mike said. Cheap and low tech. But I like it because it looks very controllable. When he pull it out of the frame the grease stayed put, didn't make a mess and was easy to put back in the gun.
-STu
My Build Log
PostPosted: November 4, 2017, 3:33 pm
PostPosted: November 4, 2017, 11:45 pm
"BUMP" This is just to see if the time stamp has straightened out! 10:45 pm CDT,11/4/2017
PostPosted: November 7, 2017, 3:35 pm
I suspect it's because high pressure manual power grease guns are readily available (and/or 'cause grease doesn't leak as readily as water).
PostPosted: November 8, 2017, 9:01 am
Lonnie
Commerical hydro-forming operations use a water base fluid with a soluble forming lube.
But even clamped together with a huge hydrualic press, they pisses out A LOT of fluid between the dies.
DaveW
PostPosted: November 8, 2017, 5:35 pm
Thanks for the link. I found this simple approach to pressure forming most interesting
PostPosted: November 9, 2017, 2:02 am
davew wrote:
Lonnie
DaveW
Colin Furze did this with a pressure washer.
https://www.youtube.com/watch?v=llhcATrmsBg
Ford 5.0 into an M3
mikaelvroom.com
PostPosted: November 9, 2017, 9:05 am
You can use a pressure washer, they produce more then enough pressure. I helped a friend to make a 2-stroke exhaust pipe. it worked well. You have to install some sort of bleed valve so you can get the air out. You can use a hammer or even a torch to massage areas that are not coming out to your liking.
Graham
PostPosted: November 9, 2017, 9:33 pm
Laminar wrote:
davew wrote:
Lonnie
DaveW
That guy is certifiable (but amusing), and I wonder what in the world he's been smoking. However, that said, there is something to his water-based method. It's definitely low cost. If you made some decent molds, it could be useful. I think I'd focus on half molds and join the halves by welding or riveting.
Thanks for the post.
PostPosted: November 30, 2017, 9:59 pm
I have an old TAB shop projects book that describes DIY'ing similar shapes with a pressure vessel formed from a steel pipe cap. Pressure came from a .38 Special blank cartridge; it fell under the category of "explosive forming."
