It is currently May 18, 2024, 4:54 pm
PostPosted: May 24, 2021, 11:54 pm
I would like to build a Locost chassis, use a Miata donor, and use the body panels purchased from Caterham. Does anyone have experience building with this philosophy? Thank you.
PostPosted: May 25, 2021, 7:36 am
You can buy the body panels, shipping would be interesting.
https://caterhamparts.co.uk/142-side-skins
Graham
PostPosted: May 25, 2021, 10:51 am
Locost bodywork is not complex and does not require a high skill set to create.
There is more than one source for the fiberglass parts.
Mounting the body is more complex than forming the panels.
Honey anyone?
PostPosted: May 25, 2021, 4:50 pm
Engine choice primarily determines the chassis size.
Chassis size determines what nose and scuttle will fit or need modification.
Wider and taller allows a flat bonnet without protrusions and good ground clearance to the oil pan.
Build for a 1/2 inch bonnet to highest point on the engine and oil pan hanging one inch below the chassis.
Wings, nose, and scuttle would probably cost about $2000USD shipped.
Going through a US Caterham Distributor would probably add to the cost.
