It is currently February 20, 2019, 7:17 am
Post new topic Reply to topic  [ 213 posts ]  Go to page 1, 2, 3, 4, 5 ... 15  Next
PostPosted: March 26, 2011, 11:57 am
Chuck (rx7locost) had a great idea of having a Megasquirt thread. Since enough Locosters are using them, it seemed like a great idea to have one stickied in place for discussions pertaining to building, setting up, and running a MS ECU.
Megasquirt Links:
Megasquirt homepage: http://www.msextra.com/
Microsquirt homepage (smaller pre-assembled ECU based on the MS2): http://www.microsquirt.info/
Megajolt homepage (controls ignition only): http://www.bgsoflex.com/mjl/mjl_edis.html
DIYAutoTune homepage: http://www.diyautotune.com (excellent MS supplier)
JBPerf homepage: http://www.jbperf.com/index.html (supplier of MS expansion components and accessories)
Electronics Suppliers:
http://www.mouser.com
http://www.digikey.com
http://www.waytekwire.com
http://www.terminalsupplyco.com
Other Useful Links:
http://www.hammondmfg.com/ (nice enclosures for DIY electronic projects)
http://www.rx7club.com/forumdisplay.php?f=153 (for 'squirting a rotary per rx7locost's suggestion)
PostPosted: March 26, 2011, 3:09 pm
Cool, I didn't realize there were more of us (except SkinnyG)!
Rod
and a 1963 Nova SS
PostPosted: March 26, 2011, 5:07 pm
One more here guys. I suspect more will chime in with time.
I would add this link specifically for those 'squirting a rotary: http://www.rx7club.com/forumdisplay.php?f=153
My setup is:
Processor = MSII
PCB = v3.0
Firmware = MS2/Extra v3.1.0
Tuning software = Tuner Studio MS v1.0
Wideband = NAW_7S from 14point7.com (no longer avalable)
My system is wired directly to my stripped down RX7 harness with no interface or expansion board. I am controlling several other engine related items with the MS2/Extra firmware.
In the spirit of Locosting, I have a JimStim that I will loan out to "established" Locosters on a limited basis (minimal refundable deposit + shipping of course)
I am willing to share what limited knowledge I have with others. I can work around the electronics side fairly well. I am just learning the tuning part of it.
Chuck
PostPosted: March 27, 2011, 4:47 am
I've got a JimStim as well, if anyone in Canada would like to borrow one. I'd like to keep it in the country to save shipping, and with someone else offering one in the US that shouldn't be a problem.
I've got my MS3X + 3.0 board built and ready to go, just need to finish the actual car now!
PostPosted: March 27, 2011, 9:52 am
I will be going MegaSquirt this summer for my 4AGE 20V. I already have one working on a Lotus Twin Cam in my Europa.
Paul Harhen
PostPosted: March 28, 2011, 11:16 am
I am still in the testing stages but here is my set-up:
-MS3X ECU with V3.0 PCB and 1.0.0 firmware
-JimStim v1.5 stimulator
-Everything full sequential
-2.0L Duratec stock coils fired with a custom igniter box
-Still unsure about the injectors since according to the MS site the stock Duratec ones are good for little more than stock power levels
-More than likely run Alpha-N with the MAP sensor as the secondary correction
I still need to sort out a pressure regulator set up since the OEM one electronically regulates fuel pressure* and buy a LC2 for my O2 readings.
*If I can sort out a closed loop circuit that can take the fuel pressure reading from the fuel rail pressure transducer and output a voltage to the stock fuel pump driver box, that would be ideal.
PostPosted: March 28, 2011, 1:04 pm
Don't forget to include Mega Jolt. I plan on using the Lite version on my Suzuki GTi motor with bike cards and EDIS. Russ
PostPosted: March 28, 2011, 2:23 pm
My Megasquirt is this:
Toyota 4AGE Bluetop, stock
Suzuki GSXR/600 ITB's
GM TPS & IAT sensors
Toyota ECT sensor
Innovate LC-1 wide band
Honda Accord injectors
Ford EDIS-4
MSIIv3.0, 2.888 code
Tuned Alpha-N
Caveat Emptor - this might get you started, but not a substitute for real tuning.
The Lethal Locost
PostPosted: March 28, 2011, 6:44 pm
I knew I had this website in a file somewhere. ..
http://www.ecuconnections.com/forum/index.php
more focused on re tuning stock ecu's but they have a lot of shared info on maps and good schematics.
PostPosted: March 29, 2011, 1:02 pm
Andy this is a great suggestion. I understand that I am not the only computer challenged builder around and I will be interested in following the discussions of the proposed EFI topic. You may want to add to your references www.microsquirt.info This is the orientation site for MicroSquirt ( MegaSquirt's little brother). I bought this hardware which is a sealed unit and I planned to set it up for ignition only for the time being.
Philippe
PostPosted: March 29, 2011, 1:29 pm
SkinnyG wrote:
If anyone wants a copy of my tables, shoot me a PM.
If you (or anyone for that matter) are comfortable posting them here, the forum software will let you upload a .zip file.
PostPosted: March 29, 2011, 3:39 pm
If any of you have full up Adobe Acrobat I've found that you can open a WORD or Excel file that just contains a Table from Adobe and then save the file as a JPEG instead of a pdf - Voila, you have a table that's visible just like a photograph. Resolution is not ideal, so don't fill the table with a tiny font.
It's more convenient than a Zip for the reader, but if there are lots of tables the Adobe approach is a bit of a slow pain for the poster.
Sorry to get off topic.
Warren
PostPosted: March 30, 2011, 12:10 am
I decided just to upload a screen shot instead. The MSQ is not always useful depending on what code you're using, and I forgot how to export the VEX file. So..... screen shot yay.
The Lethal Locost
PostPosted: March 30, 2011, 8:48 am
Thanks for sharing Skinny.
Does the ~13:1 AFR at higher RPMs work well?
PostPosted: March 30, 2011, 12:58 pm
It seems to work fine.
I understand 12.5 - 13.2:1 seems to be acceptable for NA engines. The engine seems happier around 13:1 than 12.5:1. If I lunch the engine, I have a 2.0 Duratec in my shed....
A good read: http://www.diyautotune.com/tech_article ... rt_ems.htm
The Lethal Locost
