It is currently Sun May 19, 2013 6:07 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: "Mis-Matched Headers"
PostPosted: Thu Feb 16, 2012 4:05 pm
You need a good average sample of all the cylinders in a bank to provide feedback to the computer which will affect all the cylinders of the bank. The Ford computer may change the mixture of all cylinders based on the o2 feedback on one side, even though there are two o2 sensors. I'd look into that before deciding on bung placement. It's better to be a little rich on the poorer flowing side than too lean on the better flowing side.
I will assume your going to run the heated o2s (ie, not 1-wire o2s), so distance from the head is not as important for getting up to temp and in closed loop in a timely manner.
Understood! Thanks, MV8!
PostPosted: Thu Feb 16, 2012 4:31 pm
Hey JD, what if, after running the two diff headers, you found that the left side was rich while the right side was "just right"? Since you can't change the headers while doing your tuning, you could a) change the injectors on the left to a slightly smaller injector. Or 2) better yet, install 2 separate fuel regulators, one for the right and one for left banks. Then you could balance the two sides under WOT. That is where you'll be running, right?
Think out of the box JD! You, of all people, should be able to do that! You're dissappointing me man :cheers:
PostPosted: Thu Feb 16, 2012 6:11 pm
rx7locost wrote:
Hey JD, what if, after running the two diff headers, you found that the left side was rich while the right side was "just right"? Since you can't change the headers while doing your tuning, you could a) change the injectors on the left to a slightly smaller injector. Or 2) better yet, install 2 separate fuel regulators, one for the right and one for left banks. :cheers:
Hey, what a great idea!!! Just like the old Jag V12s, I could run each cylinder bank like a seperate engine! Like it was two four-cylinders engines... Hmmm.... 8)
I think Marcus was probably correct, if I stay at full throttle more than ten seconds I'll be in the next state. I'm not sure if he meant that as in the neighboring geo-political subdivision or if he meant I'd be converted to plasma. :twisted:
Actually, if I'm thinking at all, in or out of the box, that'd be a big surprise to some folks... :mrgreen:
