It is currently May 15, 2024, 12:47 am
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Remote Coolant Fill
PostPosted: November 24, 2014, 5:56 pm
mjalaly wrote:
I will probably go At-om style and mount it next to the head
I think you'll have a hard time getting that to look decent. It works on the V8 because the engine is so tiny that even though the expansion tank is higher than the heads it's still quite low in the car. With a taller engine it's going to stick out like a sore thumb, which is why on the 4 cylinder they've got it hidden inside the air scoop - pic.
With your engine, maybe angle the IC up a bit closer to, say, 45 degrees and stick a flat-ish tank above the intake manifold? Then cover it up with an IC exhaust duct and a big shiny scoop cover like the original has.
Edit. Having never paid too much attention to the styling of the At-om I never noticed the engine cover in the back, which is probably high up enough that you could squeeze an expansion tank under it.
PostPosted: November 24, 2014, 7:05 pm
Their engine and mine are similar in overall height and their coolant tank does stick up quite a bit. They change the engine cover on the v8 to cover it, which also in turns make it look a bit better
http://www.topgear.com/uk/imageresize/i ... Height=347
PostPosted: November 25, 2014, 1:30 am
you haven't read my post have you, the statement that the cap opens because of temperature is incorrect, it is pressure.
go and read my post then go and do it.
there are three basic systems that are, have been used on liquid cooling systems on motor cars.
1. radiator and nothing else, when the engine gets hot it expells the increase in volume through a cap, either pressurized or not, to atmosphire.
2. as above but not to atmosphire but to a resovoir which is open to atmophire via a hose to the bottom of the resovoir allowing the resovoir to catch the expelled coolant, when the system cools down, the radiator coolant decreases in volume and creates a vacuum in the radiator, because of the design of the radiator cap the water is sucked back into the radiator from the cooling tank by the created vacuum, the radiator cap prevents the vacuum from drawing air in instead of the previously expelled coolant.
3. a completely pressurized system, this is nothing like the syetem described in "2". in that due to the unrelyable radiator cap seals and considerable loss of vacuum in the system , it was deemed better to just have a larger volume system in the first place.
this is a much better system as nothing is generally expelled to atmosphire but contained in the system at all times unless repairs are needed.
it comprizes of a normal cooling system as described in 2, but instead of the pressure cap being fitted to the radiator, it required an expansion tank, this is the same as in 2 but is connected directly to the main cooling system instead of via the cap, this allows coolant to enter and leave the expansion tank as the temperature rises and falls, thus expanding and contracting, the coolant is kept at a pressure to increase the boiling point above 212/100 degrees dependant upon the rating of the cap which is now located on the expansion tank, therefore the expansion tank must be located above any other part of the system to ensure complete filling and evacuation of air or steam trapped in the cooling system via a vent pipe from the highest point in the system to the top of the expansion tank.
this system should not require any additional overflow resovoir as when completely filled at hot, that is the maximum volume of the system unless there is a fault in the cooling mechagnism, be it too small of an expansion volume or overall volume through poor design, faulty electric or mechanical fans, defective pressure cap or a leaking head gasket.
this system is in essence the same as system 1, and although it looks more complex, it is just designed to accomodate the lower body styles in modern vehicles with crossflow radiators and no top tank, years ago, the expansion tank would have been just an increase in the volume of the radiator header tank, that is all that is going on with an expansion tank system, and in old cars, the radiator top was generally higher than the rest of the cooling system.
as a point of interest, if your vehicle has system 2, and when cool, there is still the expelled coolant in the resovoir, then you have either a defective cap, a leak in the system or a leaking head gasket, it will expell the coolant into the resovoir when hot, but is not sufficiently hermetically sealed to maintain a vacuum when cooling down to draw the coolant back past the cap into the cooling system.
Last edited by john hennessy on November 25, 2014, 2:04 pm, edited 1 time in total.
PostPosted: November 25, 2014, 7:06 am
:lol: So anyway Mjalaly, there is this little red "!" to report offensive and moronic statements.......
PostPosted: November 25, 2014, 11:25 am
Um i don't know if that was directed at me... i don't know where i said the cap opens due to temperature... i was just trying to figure out where to put it.
Anywhoo... have any of you guys ran across a squarish plastic one? I fond this one for cheap but it doesn't say the caps rating or which style cap can be used... and you cant see the fluid.
http://www.ebay.com/itm/OBX-Universal-C ... 87&vxp=mtr
PostPosted: November 25, 2014, 2:23 pm
mjalaly,
try post 13 on page 1.
i aplogise for any comment that may be offensive but this is basic stuff on cooling.
please read my original post and my edited and more informative last post as you may find it helpful
thanks John.
PostPosted: November 25, 2014, 3:43 pm
john,
no apology needed but that was posted way before your first post. However, i did read your last post and it was very insightful. Just because it is basic for one person doesn't mean it is for all (like marriage). Car cooling systems was never part of the the ME curriculum (heat expansion etc was though). Now i know and i am sure there are other people on this form who would find this information helpful as well.
picked this guy up for $24. Seems a little big but it may work and if not i can probably make the VW one work.
http://www.autozone.com/collision-body- ... 15153_0_0/
PostPosted: November 25, 2014, 4:09 pm
Hi,
Be sure you know how to plumb this tank - http://www.autozone.com/collision-body- ... 15153_0_0/.
The lower hose connection goes to a fitting on the water pump inlet and the smaller fitting on the top goes to the highest point in the system (preferably the output from the head). IF the radiator can trap air, then a bleed hose from the top of the radiator should also connect to the smaller fitting (using a T or Y fitting). The way this works - the water pump creates a slightly lower pressure than the system pressure in the tank when the engine is running. This lower pressure draws the slightly higher pressured air/coolant from the top of the head (high point) and the radiator (high point) back into the tank, automatically purging the system of air. The tank CAN be lower than the highest point in the system but then it must be final filled when the engine is running. Once the cap is installed and the system comes up to pressure, do not open the cap or it will "belch" coolant. Only check when cool.
Another point - make sure there is a small bypass hole in the thermostat. You WANT some coolant flowing thru the radiator at all times and it allows filling the system too be much easier.
John Rounds
PostPosted: November 25, 2014, 4:30 pm
Kartracer47 wrote:
Hi,
John Rounds
Yeah the radiator is on the front of the car vs the back where the coolant tank will be. I will have to add a bleed valve to the radiator to make sure it doesn't trap air.
while we are at it... one of the upper tubes has a check valve in it... this is for the recovery tank correct so that you cannot suck in air during cool down?
PostPosted: November 25, 2014, 7:44 pm
Yeah its too big.
I need something more compact like this i think.
http://www.speedwaymotors.com/Spike-Cha ... ,6668.html
PostPosted: November 26, 2014, 2:43 am
The check valve you refer to is NOT in the tank you are thinking of using. That tank IS the reservoir.
The check valve is in the coolant recovery style of radiator cap. The hose at the filler neck goes into the bottom of the open to air coolant recovery tank.
Good luck!!! John R
PostPosted: November 26, 2014, 10:53 am
Good luck!!! John R
John to clarify, on the dorman tank in the picture above, there is a check valve in the top port where my thumb is located. I blew into all the ports.
Its really a moot point since i need to use a different expansion tank anyway.
PostPosted: December 1, 2014, 1:20 pm
Any thoughts on how big the expansion tank needs to be??
This guy comes with everything and is 12oz
http://www.ebay.com/itm/201216423801?_t ... EBIDX%3AIT
this one is 16oz
http://www.ebay.com/itm/New-Spike-Alumi ... 66&vxp=mtr
and this one is 40oz
http://www.speedwaymotors.com/Speedway- ... aQodAXEA8Q
this one is cool too and may help with fitment issues.
http://pitstopusa.com/i-5060864-howe-al ... -tank.html
PostPosted: December 1, 2014, 3:40 pm
Normally allow a minimum of 6% over system capacity for expansion and 2% room for deaeration . 10 -15% is a better all round figure imho.
Bob
PostPosted: December 1, 2014, 3:44 pm
Yeah i have no clue what the systems capacity is...
