I run my fuel filter between the tank and the pump which then goes into the fuel rail. I have been having issues with fuel starvation and I think the fuel filter is the issue.
I was running the cheap see though ones from the local car shop as it is great for checking to see how dirty it is. However at the last event one split which ended my day early.
I decided to get a good one and purchased a K&N
http://www.amazon.com/K-N-PF-2000-Fuel- ... uel+filter however this has thinner connectors and seems to be restricting fuel flow.
Does anyone have a good recommendation for a fuel filter with 3/8" (Edit: or 5/16th) connectors, that you attache with a hose clamp. Transparent is a plus but I will take anything at this point.
Scrap Metal Build Log
viewtopic.php?f=35&t=14558
