It is currently April 18, 2024, 7:32 pm
 Post subject: Nylon fuel lines
PostPosted: August 20, 2016, 10:20 pm
Cause it's cheap and it was used in the donor car for part of the fuel line and with a bit of heat can be easily bent...
...any reason why I can't just plumb the entire Locost with Nylon fuel lines? The 95 Camaro EFI used that stuff for part of the trip, the Dorman 800-074 has a burst PSI of somewhere over 10x my fuel pump's output, etc (or so I think).
Am I missing something?
 Post subject: Re: Nylon fuel lines
PostPosted: August 21, 2016, 12:27 am
I used plastic tubing for all my fuel lines, even though I'm an instrument mechanic and running stainless tubing is something I do lots of at work and I had access to free tubing. I used Sinflex, it's a reinforced plastic tubing with Teflon lining used for truck air brake systems. It stands up to gas and oil, and the stuff I used is rated for 300 psi, so plenty for fuel lines. It's available at any heavy truck shop, as well as brass compression fittings. I used stainless steel fittings from work for my setup though, because I had a bunch of used ones that I've scavenged over the years.
Kristian
viewtopic.php?f=35&t=7587
viewtopic.php?f=33&t=18172
PostPosted: August 21, 2016, 9:21 pm
I wouldn't. I'm using hardline and AN hose because I towed too many burned-out 80s-90s GM vehicles with plastic fuel lines...
