It is currently April 19, 2024, 5:59 pm
 Post subject: Radiator outlet length
PostPosted: November 5, 2016, 10:54 pm
My radiator is currently set up with the lower outlet on the RH side, and I have a RubeGoldbergian mess of rubber hoses snaking under the steering rack and past the crank pulley and ending up at the left side of the engine where the water comes out. I have been noodling on a better way for a while and it struck me tonight during a stare-session that it's a straight shot from the bottom left of the rad, under the rack to the water outlet on the engine. All I need to do is weld up the outlet on the RH and move it to the left. My question for the masses is this:
Can I have an 18" long, 1.25" OD 16guage-6061 lower radiator outlet?? 2 90* hoses will get me from the engine straight into the radiator in a very clean and simple way. But will "pinochios nose" be a crack prone nightmare?
PostPosted: November 6, 2016, 8:14 am
Yes it will. Don't do it.
PostPosted: November 6, 2016, 1:00 pm
Bend a piece of aluminum tubing that follows the current hose routing. Use two small straight pieces of hose at each end to attach it so there is some give.
PostPosted: November 7, 2016, 4:45 pm
What Andrew said. A couple inches of rubber hose will give all the play you need.
BTW, never heard the term 'stare-session' before, but that's how I figure out most of my engineering problems.
PostPosted: November 10, 2016, 10:45 pm
I find that "Stare session with intermittent butt scratching" is the best for creative design work... :mrgreen:
