It is currently April 19, 2024, 2:07 pm
 Post subject: MAP Sensor
PostPosted: December 5, 2016, 12:53 am
Can anyone suggest a good generic MAP sensor? Is the $12 one I found on Amazon, just a waste of $12. Is an OE replacement better? I can get a GM one for about 24 according to Rockauto.
Also, am I right in believing the sensor can be mounted remotely with some good quality vacuum hose?
 Post subject: Re: MAP Sensor
PostPosted: December 5, 2016, 9:02 am
I bought an Omni 3 bar map sensor for my car and was very happy with it. However you need to retune/recalibrate the engine if you use a different Map sensor.
Honestly for something like this I would always go OEM or reman. It's not worth the hassle to have engine problems over a few dollars.
As for relocating it, I am sure you could make it work it is just a pressure sensor, however you may have to retune the engine. All the fuel trims are based off the Map sensor (Air in) and O2 sensor (air out), changing there values could lose power, efficiency etc.
PostPosted: December 5, 2016, 11:56 am
No problem remote mounting unless you have some sort of line restriction. I have 2 Megasquirted cars with the MAP sensor 4 and 6 feet away from the manifold. Megasquirt mounts the MAP sensor inside the case.
PostPosted: December 5, 2016, 9:40 pm
Did you look at the ones DIYAutotune.com sells?
Honey anyone?
