It is currently January 22, 2018, 6:09 am
 Post subject: Hose clean up
PostPosted: September 13, 2017, 11:09 am
I think all of these hoses on the back of the engine look bad. Any thoughts on how to clean them up?? Doesn't someone make a braided hose adapter for barbs/nipples?
 Post subject: Re: Hose clean up
PostPosted: September 13, 2017, 8:26 pm
Call Speedway in Nebraska and have them send you a catalog. They carry a wide range of Aeroquip and other push-on hose and fittings at pretty good prices.
PostPosted: September 13, 2017, 9:03 pm
Much cheaper to go the route of expanded braided sleeving on those.
https://www.cableorganizer.com/braided-sleeving
If you clean the hoses up nice, sleeve, then use some marine/adhesive lined shrink tube on the ends, it will look really good. You can use standard clamps over the heat shrink without issue.
Another trick is to clean the nipple and the inside of the hose with alcohol, then use some hairspray on the nipple and slide the hose on. Shrink the shrink-tube, and it should stay put for vacuum lines and boost reference lines.
For pressurized coolant, I'd go with new spring clamps or oetikers.
Walt
04 RX-8 Touring RIP
90 Ram 50 4x4 V6
91 3000GT VR4
