It is currently April 19, 2024, 3:18 am
 Post subject: Low cost adjustable FPR
PostPosted: December 14, 2017, 9:18 am
I'm using an OEM FPR, works fine but it looks like crap and for safety reasons, would like to use stainless braided return line, so universal FPR's look attractive. They seem to come in two price categories, cheap and WOW!. Any good ones in the cheap range?
Bill
PostPosted: December 17, 2017, 2:33 pm
Okay, time to fess up.
Several ago, I purchased one of the cheap regulators. Nicely made, but absolute failure as a regulator. Operating on 70 psi (air) it is impossible to regulate flow. When the adjustment gets to the point that pressure starts to drop, it drops suddenly and shuts off. Will not resume until the adjustment is backed way off, at which point it jumps up to 70 psi. The "jump", or release is so sudden, I can actually feel it. Installed a weaker spring, same story but at a different in the adjustment range. I have taken it apart, everything is clean and really looks good.
Why would a pressure regulator be "sticky" in action?
Bill
PostPosted: December 17, 2017, 4:29 pm
Normally I'm all for building/modifying stuff, but wouldn't mess with a FPR. Just too much on the line: leaks, inconsistent operation, fuel incompatibility, or worst case, suddenly making the engine go dangerously lean.
PostPosted: December 17, 2017, 9:57 pm
How does steel braided hose increase safety?
The words fuel pressure regulator don't apply to EFI regulators.
They are really pressure relief valves.
Honey anyone?
PostPosted: December 18, 2017, 9:07 am
The helpful hints are so overwhelming, I don't know where to start.
Bill
PostPosted: December 18, 2017, 10:14 am
Disclaimer: I have not worked on a FPR, but on hydraulic systems it could be the angle on the seat is to steep. Realizing that we are talking 1000 to 3000 PSI Vs 30 to 70 PSI for an EFI. There is a hell of a lot stronger spring pushing on the back the piston seat, which causes it wedge in place on the pressure relief valve. Dave W
PostPosted: December 18, 2017, 4:26 pm
No angle here. The mating surfaces are a disc and flat seat. About as simple as things can get. I was hoping someone would say, "Hey moron, y'er hooking it up bakards". Speaking of backwards, I tried that. It worked a bit better, took maybe 5 seconds to shut completely off.
Bill
PostPosted: December 19, 2017, 12:26 pm
They're typically bypass regulators. The high-end carb regulators work the same way, with a return line to the tank.
PostPosted: December 19, 2017, 1:02 pm
I would take a look at the shape of the valve seat. It sounds to me like what's happening is that when the valve starts to open slightly, the flow forces it open significantly and the pressure drops off. A good valve would have a bit of taper in either the seat or the "needle" that closes the valve. The needle is often a ball rather than a needle. If it's a flat disc that closes off the flow, then that's probably the issue right there. It would be very hard to control that. Do you have a pic of the internals?
PostPosted: December 19, 2017, 2:28 pm
You may be right about finding a cheap one. This one is not cheap, but I thought it was good quality. You may be able to find generic knockoffs of this unit. The reason I liked these folks was that if you go through their web site, they hav published graphs of the "error slope" for their units. What that means is it tells you the quality of the regulation, if you double the input volume, the output will change a bit too and they show you what that is.
Whenever you see that type of information it tells you that you are dealing with people that actually designed something and didn't throw it together or copy someone else's work etc. So according to their site the mini fuel regulator is smaller but it has a larger error as the fuel source pressure varies...
https://www.summitracing.com/parts/fue-53501-1/overview/
Maybe your problem is that your source of air is far beyond the units ability to regulate? I don't know why but air is different than fuel and when the unit opens up is is not relieving the pressure so it open too far and jams?
PostPosted: December 20, 2017, 2:16 pm
Is the unit you have intended to regulate (go in-line between the pump and rail) or to pressure relieve (between rail and a return line) which is more typical.
They function differently and if you are trying to use one for the other, you will have issues.
Operating on air, you may have issues that will not occur with fuel (or water, etc.) based on compressibility and viscosity differences.
Can you describe your test setup? I'm not really following your description of events very well, what adjustment are you making and which pressure starts to drop? If this is a return flow device, there should be no pressure on the outlet line, but you specify working with 70 psi air, so I am assuming you are supplying air from a regulator on a compressor to the inlet of the device, so that regulator will compensate flow until you get outside it's capacity (too much, or to low for it to regulate) and things will get funky fast. Regulators directly in series do not always behave as nicely as they might.
PostPosted: December 21, 2017, 8:42 am
BINGO!
Yesterdays posts prompted me to question my setup. Well, I was treating this regulator like an air pressure unit. As Sgt Bowe, my basic training Sgt used to say, "We don''t do it thataway!". The problem was me, not the regulator. :oops:
Properly plumbed into our domestic water system, the little regulator gave smooth response up to its flow capacity.
Bill
cron
