It is currently April 18, 2024, 5:11 am
 Post subject: Fuel cell level sensor
PostPosted: March 12, 2019, 11:51 am
I’m building a fuel cell for my car soon. Just gathering material and parts. With the fuel cells I have built in the past, one thing has always bothered me. Not having a way to tell the fuel level without looking inside. Especially when (or if) you have the anti-slosh foam on the inside.
So, anyone here use some sort of level with a gauge that works well in a custom fuel cell? Maybe one that works well with the foam?
PostPosted: March 12, 2019, 1:04 pm
I've used these capacitance senders in my airplane. They work quite well, and you should be able to stick the probe through the foam. No moving parts.
https://www.aircraftspruce.ca/pages/ep/ ... lFuel3.php
Martin
My build log:
My build video:
PostPosted: March 12, 2019, 1:44 pm
So by looking at it, I am guessing you mount it at the top of the cell. The long "probe" part will read the level?
This would work with any 5v aftermarket or OEM type of fuel gauge?
PostPosted: March 12, 2019, 2:36 pm
New thing for me!
A quick check shows a much less expensive version on eBay (of course, right?) but the interesting part is that they link to an adapter that uses a voltage to resistance converter for use with "any gauge" Click here: Voltage to resistance converter
It may be of some help
PostPosted: March 12, 2019, 4:12 pm
sen2two wrote:
So by looking at it, I am guessing you mount it at the top of the cell. The long "probe" part will read the level?This would work with any 5v aftermarket or OEM type of fuel gauge?
Yes, you mount it through the top; if you are making your own fuel cell, you can add a backing plate. The probe will be the depth of your tank, as it measures a change in resistance as the fuel encloses the probe (correct me here, Chuck, if I got this wrong).
You are able to shorten the probe to match your tank, however, I believe there is a limit as to how much. And it works with a regular fuel gauge.
I wouldn't shove the probe through the foam, but core a slightly larger hole so that the probe is properly surrounded by fuel.
Martin
My build log:
My build video:
PostPosted: March 12, 2019, 5:57 pm
Awesome. And you may have answered my next question which was can I cut it to length. My fuel cell will not be that deep. As of right now I have it drawn out to 8in in-depth.
PostPosted: March 12, 2019, 7:56 pm
Martin and sen2two, From what I read, the sensor measures the capacitance and converts to a voltage. It should be very linear since the capacitance between 2 conductors, is directly proportional to the dielectric permittivity (dielectric constant) of the material between those conductors. IE, as the fuel level increases, so does the capacitance. There is a circuit that converts that capacitance to a voltage. It also has low and high fuel level adjustments.
It look like the Aircraft Spruce gauges take a voltage signal which this provides. If the "gauge" you wish to use requires a 0-5V voltage signal, then you should be good to go. Most OEM gauges I am familiar with use a variable resistance for the signal. Some use that as part of a internal voltage divider, some use that resistance in a bridge circuit. Those gauges also use sensors with different values of resistance. Worse yet, some have max resistance at low fuel, some have max resistance at full. This makes it impossible to make a blanket statement of what is right without knowing the requirements of the gauge itself.
I mentioned the adapter which is apparently programmable for all of these "resistance" variables and accepting a 0-5V voltage range, just like the Aircraft Spruce sensor.
The AS sensor can be bent and angled so that the entire length can be used without having to cut it to length. Can it be accidentally bent while refuleling? IDK. For ~$80 less than the AS part, that's right only$37 delivered, is the eBay one. It cannot be bent like the AS sensor, but can be cut between 6.6"-10" long. See below.
https://www.ebay.com/itm/Fuel-level-sen ... SwwKtZi3FE
I hope this helps.
PostPosted: March 12, 2019, 10:10 pm
Correct, the sensor sends a voltage, while nearly all gas gauges measure current. Unless you buy the recommended gauge, prepare to do some electrical engineering.
PostPosted: March 13, 2019, 7:45 am
I wanted something that would not corrode with a standard output value so I could find a matching gauge at a low cost. Come in many lengths but I guess you could modify.
https://www.ebay.com/itm/150mm-Marine-F ... SwVpRbMfTL
PostPosted: March 13, 2019, 9:16 am
This type of sensor seems perfect for me, except for it will not work with an OEM fuel level gauge. Which is what I was after.
When looking for gauges, how would I know that a gauge will work with this sensor?
PostPosted: March 13, 2019, 9:32 am
Sen2two, MV8's proposal will work with some OEM fuel gauges. It says Output Signal: Standard American 240-33 ohms. You need to do research to find out if your OEM gauge uses these sensor values.
What year/model car's gauge are you trying to use?
However, there are at least 2 downsides to MV8's proposal. It uses a float that rides up and down the outside of the tube. If you use foam in your tank, then it may interfere with the float. And it is not adaptable for tank depth.
PostPosted: March 13, 2019, 5:23 pm
Search for "Floatless fuel level sender" on google.
Most will be from VDO.
This place sells them in various lengths.
http://www.tanksinc.com/index.cfm/page/ ... prd346.htm
My build -> viewtopic.php?t=15585
PostPosted: March 14, 2019, 7:21 am
It will be advertised as "240-33". I just bought a 250mm sensor and gauge. You want the sensor to be as long as possible so it is most accurate near empty. Here are some gauge options. The first gauge below is compatible with multiple sensor input ranges.
https://www.ebay.com/itm/New-Type-Fuel- ... SwDJZb7sBs
https://www.ebay.com/itm/1p-52mm-Digita ... SwWIJb-~Hm
https://www.ebay.com/itm/Universal-240- ... Sw7fBa2FPP
https://www.ebay.com/itm/2-52mm-Univers ... 3049946083
https://www.ebay.com/itm/VDO-Allentare- ... 2319977797
If you want foam,make it a tight fit so the foam doesn't move around and leave an inch gap around the sensor. Even if the foam moves enough to touch the float, it should return when you straighten out. Won't be checking fuel level when hard cornering anyway. My aluminum tank came with filthy foam that I won't use primarily because I don't want to get stranded with a clogged filter because the foam isn't fully compatible with the blend in my area. If making a tank, just weld in some baffles.
PostPosted: March 14, 2019, 10:57 am
Thank you!
Going to look around and purchase a gauge and sensor asap. The fuel cell is designed now. Just need to order the material.
PostPosted: August 19, 2019, 1:36 pm
I just found this thread. I am a manufacturing engineer for the manufacture of these exact type fuel probes for all sorts of mass produced aircraft. I had no idea that the Chinese had lifted our tech and are making cheap versions. To be fair, our products date back to the 1950s using this style of fuel probe, so this isn't exactly new. We just happen to make the majority of them for the larger applications.
There are 2 probes in this type sensor. An inner and an outer probe. The fuel acts as the dialectric in this capacitive probe. More fuel between the two tubes, more capacitance. Cutting this down will definitely mess with how accurate it is, though in our cars, that probably doesn't matter too much. This is likely to be far more reliable and accurate than a float could ever be, especially on a track sloshing around.
cron
