The schedule 10/40 pipe is usually used to build a turbo header. You could build a full N/A header with it, but even schedule 10 is nearly 1/8" thick and weighs 2 lbs/ft. If you have four 32" runners going to your collector, that's 23lbs in runners alone, plus collector and flanges. With a massive 1/2" thick header flange at probably 8 lbs and your collector being another couple pounds, you just made a 35lb header.
For reference, each of these has a 5/16" header flange, 4 x 33" 1-5/8" mandrel-bent primary, slip-fit collector with an 18" long 3" secondary and a 3-bolt flange. Each complete header weighs 15 lbs.
Also, you picked a mild steel flange, unknown pipe (probably mild?) then a stainless collector. Do you have the equipment available to weld mild up to stainless?
Your head flange and piping are turbo parts and are way overkill for an N/A header. A 5/16" or 3/8" head flange is more than enough for a simple N/A build. You can buy a set of mandrel bends
for cheap. I built those headers for less than $300 for the pair.
