Driven5 wrote:
robbovius wrote:
IF vehicles like this become popular
Fixed. Reverse trikes have been around for over a century, and all their various attempted forms have yet to go anywhere even close to mainstream.
the many people who bought Morgan (and other branded) three wheelers, and made them rather mainstream in the british market during the 1920s and 1930s (due to three wheel cars being taxed at a lower rate) would argue with you...if they were alive, which they probably aren't...so...um, I'm arguing as their proxy? Works for me.
in order to see the true place of the three-wheeled vehicles in the toality of the automotive world, you really have to look outside the american market. The market here does not favor three wheel vehicles, and we never had any weird tax laws that based on how many wheels contacted the ground, or engine bore diameter.
Driven5 wrote:
robbovius wrote:
apparently, Bosch tuned the stability and tracton control to allow both donuts, and drifting
can't do that with FWD.
Really? According to who?
well you quoted me, so, me. so there. so anyway...
Driven5 wrote:
Just because it hasn't been done in a production capacity before, doesn't mean it can't be. It just takes looking beyond the conventional. Independently controlled brakes can be wonderful things, even in manually actuated form. Once (IF) the right company put the right engineer in charge, all it would take is the right stability and traction control programming to also "allow" a high-performance production FWD to do both donuts and drifting.
ERRRT! Driven gets the buzzer. applying the brake to make a car slide or drift is a handbrake turn (adn that's what's going on in the viddy you linked) , whether the brake is applied by either the robot in the dash panel or the nut behind the wheel. Proper donuts require rotating the car in what is fundamentally a tightly oversteered circle, with the rear tires spinning so that their slip angle describes a arc that is functionally concentric with the much smalled slip angle being described by the front tires.
In a FWD car, how are you going to spin the rear tires to perform that donut? Donuts, can be driven into and continued as long as you have the power down. Can't do that in a FWD. If you can, then its not FWD. AWD can do that. FWD? ERRRT! nope.
Oh sure, you can lock up the rear tires and spin it, but, that's not a donut.
Cue the Handbrake turn video link. I bet he's got 60-70 PSI in those dinky rear tires. I wonder if he's also got split control braking on the front wheels, since when he's doing those nifty little spins, the inside front wheel does not appear to be turning, but the car is pivoting around it.
Driven5 wrote:
OKay, I'll give him the Stoppie
can't do that in a RWD.
OMFG that video is such a honeypot! Irish autotesting? whaaaaat? How did I not know about that?
Justin I'll make you pay!
;-P
The B-3 build log:
http://www.locostusa.com/forums/viewtopic.php?f=36&t=13941 unfortunately, all the pictures were lost in the massive server crash
https://www.locostusa.com/forums/viewtopic.php?f=36&t=19012Again, all pictures were lost.
