Run87k wrote:
Sorry, no convincing arguments so far.
I did learn a couple of interesting things though. One, bump steer in the front dive condition can decrease front traction enough to lengthen braking distance. Two, bump steer can be used as an offensive weapon in chariot design.
Let’s take a look at suspensions for a moment.
Toe in – Having the toe wrong will completely mess up handling and ruin your tires. This is worse than bump steer.
Camber change during suspension movement – Swing axle cars are a good example of what can go wrong here. Ralph Nader didn’t base his career on bump steer.
Caster – I had a Beetle with nearly none. It was darty and would not return to center. It had to be held straight. Waaay worse than bump steer.
Tires – You can totally transform a car when you replace crappy tires with the right ones.
My experience sorting out the B-3 handling causes me to agree wholeheartedly with the above. I have bolded the two which I consider absolutely key.
like you my rack (Porsche 924 manual) is not optimal lengthwise for the control arm lengths, as the inner tie rod pivot point is approximately 4-4.5 inches inside the line defined by the upper and lower control arm pivots.
when I first assembled the front end, I had placed the rack so that the tie rods were level with the ground, but could easily see that the tires would toe out when I jounced the frame downward.
my solution was to measure the effect on toe thru 2 inches of bump, and 1 inch of droop, and then position the rack vertically such that bump -
within that range - was as close to zero as I could get it. then I just sprung the front end stiffly enough to ensure that suspension movement rarely exceeded that range.
with all that, the steering was only slightly darty.
BUT, the greatest improvement in steering stability happened when I replaced the bias ply rear tire with a radial. with that change, 80% of the dartiness in steering disappeared. I experience a further reduction in dartiness (which was already minimal) when I increased toe-out this past spring.
I don't notice any kind of directional instability when the suspension is in bump. all the improvements I've seen in steering stability have come thru managing toe, and tire selection.
The B-3 build log:
http://www.locostusa.com/forums/viewtopic.php?f=36&t=13941 unfortunately, all the pictures were lost in the massive server crash
https://www.locostusa.com/forums/viewtopic.php?f=36&t=19012Again, all pictures were lost.
