rx7locost wrote:
Funny thing is, if you are used to driving those 50's and 60's cars, then the fall back, motor memory, habit, etc is to put it in neutral AND depress the clutch. The added clutch and/or neutral switch has NO VALUE whatsoever.
I disagree. The actual funny thing is that if you're already operating it correctly anyways, then the clutch safety (or neutral safety) switch on a street driven vehicle CANNOT BE AN ANNOYANCE whatsoever. Just because a device should be a totally transparent redundancy that does absolutely nothing when used correctly, does not diminish it's potential value if somebody tries to use it incorrectly.
Maybe I'm just in the presence of greatness though. Apparently I'm the only one who has ever made a mistake on something I've done right a thousand times before, but just got complacent, or momentarily distracted at an inopportune time, or maybe just had a lapse in memory where I genuinely thought I had followed every step correctly but had actually missed one...And am only able to pretend I am incapable of such errors, if I wanted to, because I was extremely fortunate in those instances.
I for one don't see how any of the above anti-safety-device-purely-for-the-sake-of-being-anti-safety-device rhetoric applies to a clutch safety (or neutral safety) switch on a street driven vehicle in the first place. In fact, I don't see how any of the other arguments against it even makes logical sense. Since the operator still has to physically perform the task
that they should be performing anyways, that's not 'counting on a safety switch', or 'letting machines do the thinking', or any equivalency to active safety devices, and certainly doesn't make the operator dangerous on older machinery in which they should be doing exactly the same thing that they are already doing. Consider who is actually more dangerous on any given piece of machinery? The person who assumes their old practices are inherently the best practices on any given piece of machinery, new or old?...Or the person that takes the time to make sure they've learned the current best practices to whatever piece of machinery they operate, new or old, before actually trying to operate it?
Because I want to be able to let any other enthusiast drive my car without having to concern myself with whether they're too old-school to follow modern best practices on a piece of machinery they're not intimately familiar with, I'll be putting a clutch safety switch on it that requires the clutch to be pressed all the way against the clutch stop. If my trans had a neutral sensor readily available, I'd probably have a neutral safety switch as well, but beggars can't be choosers.
