It is currently May 19, 2024, 9:16 pm
 Post subject: Bolts
PostPosted: February 5, 2022, 5:14 pm
This shows why our local hardware store has so many different nuts and bolts. And beyond this there are bolts of different materials like brass or stainless or chrome plated.
https://www.hagerty.com/media/maintenan ... 1e0b6805ea
 Post subject: Re: Bolts
PostPosted: February 5, 2022, 6:17 pm
Hey, thanks Russ. I thought this would be a refresher for me. In fact, I picked up 2 things I didn't know: the number after the decimal for metrics, and that inch threads were incremented by 13 thou per size. i.e. a number 10 screw is .026" larger than a number 8. I knew the rough sizes for #4,#6,#8,#10, but not the theory behind it. Now, ask me in a couple of weeks and I might not remember these things. :mrgreen:
For cross-headed screws that look like Phillips, I am aware of 3 different styles that look virtually identical. The ones with no marking on the head, are Phillips head screws. The ones with 4 small radial tick marks between each of the 4 slots are PoziDriv, and the ones with a single dot between two of the 4 slots are made to JIS standards. Each have their own screwdrivers required. For instance, there are no Philips screws in any MG. They are all Pozidriv. this is why many of these cars have cross head screws that are bunged up. The American POs used Phillips screwdrivers when working on them. Japanese motorcycles (and sewing machines) used JIS screws. Same thing goes for those bunged up screw heads.
PostPosted: February 5, 2022, 7:41 pm
I'm replacing the 3/8 weld stud on each U brkt that holds each end of the LCA on the spitfire with 7/16 grade 8 bolts that can be replaced without welding. To be fair, the original triumph parts are good enough unless like me, you're converting to heavier everything.
I prefer a dial caliper to determine shank od.
Even the cheapest tap and die sets include a metric or sae thread gauge.
PostPosted: February 6, 2022, 10:47 am
Wood working types are even more numerous.
