It is currently April 16, 2024, 1:41 pm
Forum rules
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: April 23, 2020, 9:47 am
But sometimes rain just happens...
PostPosted: August 17, 2020, 8:55 pm
Fellow backed out of his parking stall with the wheels turned, and nerfed my Super 7’s left rear fender. Dude was honourable, took ownership of his accident, and we just settled in the parking lot.
I took it to a local body shop that wanted $525 (off the top of the head) to fix it. I’m pretty sure painting a new fender is going to be cheaper. However, I don’t know if Curtis Unlimited is still around.
Meantime, I bought some fiberglass and some resin, and I’m going to try my hand at fixing it. Not how I expected my day to go, but life is like that.
[img]gwellwood.com/wordpress/wp-content/uploads/2020/08/DSC06695s.jpg[/img]
As of this writing, the defects have been ground down (the fender actually delaminated the front half), and three layers of fiberglass are curing on the inside. I’ll deal with the top tomorrow.
The Lethal Locost
PostPosted: August 17, 2020, 9:32 pm
Check with Jack at Kinetic. He has access to some of Curtis's molds.
PostPosted: August 18, 2020, 2:11 pm
Three layers on the bottom, three layers on the top. Heading into town today for some kitty hair, filler, and paint.
The Lethal Locost
PostPosted: August 19, 2020, 8:18 pm
Driver's side ready for paint. And I pulled the passenger fender off too, since I can't have one shiny and new, and one peppered with rock chips....
The Lethal Locost
PostPosted: August 19, 2020, 8:37 pm
Argh! Contaminating the shop with bondo sanding dust and fiberglass itchies....
Honey anyone?
PostPosted: August 20, 2020, 12:38 am
Did you mention to the nice fellow that backed into your 7 that there cars are pricele$$?
Hope he gave you a signed cheque that you fill in the blanks.
PostPosted: August 20, 2020, 4:16 pm
And four coats of 1986 Corolla GTS Red:
The Lethal Locost
PostPosted: August 21, 2020, 7:35 pm
Sprayed some bedliner, which sucked (next to no texture), so I ended up running a roller over the wet paint to "pull up" some texture. I also made the bedliner taller (16" measured vertically off the bottomest part of the fender, that's probably 4 or 5 inches more) and wider (wrapping around the curve) as 14 years of rock chips required.
I bought some cut polish, but haven't decided if I'm going to bother or not.  I hope to install the fenders tomorrow.
The Lethal Locost
PostPosted: August 22, 2020, 12:07 pm
You might put some bedliner inside the fender also. :D
PostPosted: August 22, 2020, 12:15 pm
Rubberized undercoating is on the inside. I did that way back when as well (14 years ago), to prevent rock chips from "starring" the 'glass from the inside.
The Lethal Locost
PostPosted: August 22, 2020, 2:39 pm
And we're back together!
The Lethal Locost
PostPosted: August 22, 2020, 2:42 pm
Also changed the fender mounting to Nutserts and stainless panhead bolts. I didn't have a nutsert gun when I built it, and it's so much more convenient if you sue them.
Also changed the windshield bolts to stainless panhead bolts.
The Lethal Locost
PostPosted: August 22, 2020, 7:23 pm
And video:
http://www.youtube.com/watch?v=_0kbJr_iesc
The Lethal Locost
PostPosted: August 23, 2020, 2:06 am
The video was fun. Learned a bit. Thanks Teach!
Larry in Seattle
