It is currently April 28, 2024, 3:22 am
Forum rules
Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: September 11, 2013, 9:19 am
flealr92 wrote:
Great build, impressive craftsmanship. Any tips, stories, lessons learned or experiences you would like to share from building this car ? Maybe a general conclusion.
It'll all be in the book, which has been delivered to a real copy-editor who'll hopefully save me from myself on grammar. Handling observations and conclusions will be added after the track event, and the goal is to release the book around mid-November.
Once the book's out then I can relax a bit and add some thoughts here.
PostPosted: September 12, 2013, 10:28 am
The new book is out! The new book is out!!!!
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: September 12, 2013, 12:40 pm
I hope the following scene isn't along the same lines, "It's the book, he hates the book!" as he ducks for cover.
PostPosted: September 12, 2013, 1:27 pm
I'm presuming this means YOUR book is out?
PostPosted: September 12, 2013, 2:16 pm
Mid-November is the goal and so far it's on-track.
PostPosted: July 22, 2016, 10:44 pm
Wow, almost three years!
I still have the car, still drive it, and am still learning to live with a turbocharged engine. In short I'll say that a turbo engine on the street is great, at the drag races it's great, at track day events... not so much. They can last, but it takes cubic dollars to do it right and few do. I thought I had and was more than a little surprised when, right as I caught up to a Porsche GT3 (!) I felt the engine go weak, like a plug had quit. The engine was still running fine, just on three cylinders. As I coasted to a stop there was a bit of smoke, which told me it wasn't going to be cheap. No it wasn't.
I managed to bend an 800hp rod on edge; I can only imagine the forces involved. I reached into the pan from under the car to retrieve it, so it was clear then that the car was going to be sidelined a long time. Long story short, I showed all the broken bits to no less than 12 experts and of course got 12 different opinions - I'll never know for sure what happened.
Anyway, a new engine is back in the car now and I'm currently retuning everything. While the engine was out I decided to change things around, moving the dry sump tank to where the intercooler was, moving the turbo to behind the engine, and moving the intercooler to laying flat above the engine. For better or for worse, Midlana is going to have an F1-type intake for the intercooler; I'm still decided where to get intake air from.
More soon.
PostPosted: July 22, 2016, 11:07 pm
Post a pic of the pieces and I'll give you a 13th opinion!
Very nice looking car, if it drives half as good as it looks, Winner!
Honey anyone?
PostPosted: July 26, 2016, 12:05 pm
Here's a few of the sad/expensive pictures. Hopefully I won't have to see this sort of thing again:
PostPosted: July 26, 2016, 7:03 pm
Is that the bearing in the lower left corner of the pan (down to the copper)?
If so I'd have to say, the bearing went first, then it beat the piston against the head til it or the wrist pin broke then carnage ensued.
My next thought (if I am on track) is why did the bearing fail? It appears to be dry sumped so it should've been getting oil....
That leaves debris, machine work (fit), bolt torque (failure), detonation (can pound a bearing out and open up the big end), Over rev (or other abuse).
What did the other cylinders look like, did any other pistons hit the head, was the head gasket intact (hydrolock)?
Is that 1 rod bolt fell out and the other broke? That would reinforce the bearing failure first scenario.
Honey anyone?
PostPosted: July 26, 2016, 9:36 pm
Hold on there Rocket Shot, that's the piston pin bushing.
Bearings were perfect
Zero scuffing on the cylinder walls
Pistons, depending which "expert" I showed them to, half said they were fine, half said they were hot. Piston bottoms showed
zero evidence of heat
Plugs, half said they were fine, half said they were hot.
Bearing journals were perfect, no sign of heat discoloration
The very loose theory is that a rod bolt broke, but beyond that (like "why") everything sort of petered out and I've got nothing.
I just realized that this stuff should be in the build diary and not here...
PostPosted: August 24, 2016, 9:44 pm
Very sweet. The performance is crazy. What turbo are you using?
Steve
PostPosted: August 24, 2016, 10:16 pm
GTX3576R with a (new to the car) T4 1.04 AR turbine housing. In the process of retuning and a million other things: intercooler ducting, failing engine mount, etc.
PostPosted: August 25, 2016, 1:04 pm
How much pressure were you running when the failure occurred, Kurt? Do you plan to run less pressure with your new engine?
PostPosted: August 25, 2016, 2:16 pm
It was at around 14 psi on E85 which should have been fine since the tuner had it at the same pressure on gas. I have yet to get the tune reviewed but the air-fuel ratio is good now. What is up in the air is ignition timing and I'm not sure I'm all that good at reading plugs.
As for running less boost this time around, no, not really, once the tuner gives it a thumbs up - though he did so with the last engine, but I digress.
PostPosted: August 31, 2017, 11:47 am
Another year's gone!
Since the last update I fabricated composite ductwork to run air from above the windscreen into the intercooler, pic below.
Around last November I got burnt out on sanding (and working on cars non-stop for around 15 years). Around the same time I decided to redo our koi pond and filtration system and that's consumed the last nine months - and counting. Managed to drive the car exactly once since then.
What brought me back here was a mini-rant about small businesses, about how the only one you can really count on is yourself. I ended up dropping off the composite pieces at a paint shop, asking them to finish the sanding and to paint them. I was told "two weeks" and still kept a straight face, knowing that paint and body shops are the absolute worst places to get an honest time appraisal. Two weeks came and went - it didn't really bother me since they'd been sitting in my own garage for 8 months. After four weeks and no callback, I asked what was going on and heard what I've heard so many times "I've been out sick but it'll be ready for paint next Monday." That was two weeks ago. My brother says the only way he gets stuff out of shops is to micro-mange/babysit them incessantly. Sadly, I have to agree. I guess I'm taking sad pleasure in having yet another vendor prove that nothing's changed. The irony for me is that the shop told me how long it would take. They were free to have said "two months", but didn't. I didn't dictate any timeframe whatsoever, so it's entirely their own doing. Sigh.
