It is currently August 7, 2020, 2:35 pm
Post new topic Reply to topic  [ 716 posts ]  Go to page Previous  1 ... 44, 45, 46, 47, 48
PostPosted: July 18, 2020, 10:30 pm
I figured I might as well learn to wrap today.
Gavin
PostPosted: July 18, 2020, 11:10 pm
Does that wrap look as good in person as it does in the photo? :cheers:
PostPosted: July 19, 2020, 1:48 am
Good going Gavin! Looks great. Now the nose cone and rear fenders. They will be a bit more challenging. Anxious to see how you deal with them. Mine turned out 20/20. Twenty MPH or 20 feet aWAY.
What film are you using? Like the color. I used Vvivid.
Cheers!
Larry in Seattle
PostPosted: July 19, 2020, 8:28 am
Thanks guys, yes it does look that good IMHO.
I am using Vvivid's "Smurf Blue" which they also call "Porsche GT3 Blue". The only issue I am having is that it isn't sticking where I had to heat and stretch it on the top corner. I am not sure how to get it to stick. I tried heating it and it doesn't seem to help.
Gavin
PostPosted: July 19, 2020, 10:34 am
3M makes a liquid edge sealer and an edge sealing taper. We used to use the liquid stuff at work on pesky truck decals.
PostPosted: July 19, 2020, 9:04 pm
Thank you, i will look into using it. I am pretty happy with the result with the wrap (except the edges that I mentioned). It is much better and cheaper than I would have accomplished trying to paint it myself.
Gavin
PostPosted: July 19, 2020, 9:10 pm
That looks pretty sweet Gavin!
Mind if I ask what it cost?
Trochu Motor League
PostPosted: July 19, 2020, 9:26 pm
Thank you Josh.
I bought 2 rolls of Vvivid Smurf Blue 15'x5' @$115usd each on Amazon ($230). I was able to do both sides with 1 roll cut length wise to 30" wide x 15' long. I had a good bit left over that I am hoping will cover the front fenders. I used part of the second roll to do the rear but I have most of that roll left and will use it to wrap the bonnet, nose, and cowl. I also bought a $10 wrap kit with squeegees and some RapidTak spray ~$25 to wet things down.
The carbon used on the dash was also Vvivid and was $79usd for a 7'x5' roll :shock:
All in, I guess I spent around $350. My 13 year old daughter helped me the whole time and kept repeating how great it is to spend time with me and do "stuff". That alone makes it worth every penny.
Gavin
PostPosted: July 20, 2020, 7:27 am
Very nice :cheers:
PostPosted: July 20, 2020, 8:04 am
I like that blue! Car is looking good.
PostPosted: July 31, 2020, 10:41 pm
As I have been reassembling the car I have realized that there are few elements that I need to account for, like brake hoses. originally, I had welded some tabs on the chassis to support the hose/line union. Without a body, this worked great. But the body is so far from these tabs that it would not allow the full articulation of the front wheels with steering so I had to come up with plan B. I created some mounting br@*cktz to move the location of the hose on the chassis toward the rear LCA mount. I used 14ga scrap on a 1" flat bar with a deep dish socket cut for the hex of the hose end. At first, I mounted them outboard toward the body but my hoses were too long (first time for everything), and the tire rubbed on the hose at full steering and full bump. So, I swapped sides with the brackets to move the hose end in 1" and that was the ticket. I have ~0.75" of clearance with the tire.
Gavin
