The amazing technicolor 7 is no more. Its now in rat-rod mode for the time being.
I started by filling the seam with Bondo to reduce the amount of filler required later. Then I applied 3 tapered plies of 6 oz glass cloth to the outside of the nose.
It was finished with Icing (and a ton of sanding).
File comment: A little block sanding shows all - still needs a little more filler.
Finally some primer and all of the fiberglass parts are one color.
File comment: Can't tell it was 2 pieces.
I don't have a ton of miles on the car but little stones have already put a ton of really nice chips on the leading edge of the rear fenders. I guess stone guards are a must-have item.
After the oil pan incident everything has been pretty uneventful. The car currently has a little over 1,300 miles and everything seems to be holding up.
I have been curious how the front fender mounts would do since they are made with much smaller material (1/2" 0.063" steel tube) compared to your typical Locost design . My theory was that by making the entire mount flexible and of the same sized material the stress would be more evenly distributed rather than being concentrated where the flexible 1/8" strip meets the stiff 3/4" tube. Time will tell but so far nothing has parted ways and there are no visible cracks. This probably means they will fail within the next week or so.
The crap PA weather also forced me to make a roof (3 of the 5 autocrosses this year have been in the rain). A little Appalachian Engineering was used during its construction as evident by the crooked rear edge and the bungee cords.
